Old 03-15-2019, 03:56 AM   #1
QBRacing
58 SWB + C4 + LS1 - Header Help
OK. Getting closer to finalising the engine bits an just wondering what the LSx conversion people are running for headers when the use a C4 Corvette setup like the flatout engineering kit.
I tried the factory cast headers I have from the Holden I got the engine from and they just touch the bolts on the rear upper arms by the exit of the exhaust ports for #3 and #4 cylinders .... If only they were steel and I would have just massaged them slightly. (refer my attachments)
Next has anyone heard of or used speed-engineering. He has a couple of sets of conversion headers which look like they should work (1021 and 1029) but before I commit I'm thinking why not ask as someone bound to have played with this before.
Q
QBRacing is offline   Reply With Quote
Old 03-16-2019, 10:00 AM   #2
bigdaddyfuselier
New Member
Re: 58 SWB + C4 + LS1 - Header Help
Try 2014 camaro exhaust manifold.
bigdaddyfuselier is offline   Reply With Quote
Old 04-03-2019, 04:36 AM   #3
FleetsideBill
I used the speed engineering headers they fit great
Iím not sure how it will work with your motor mounts and steering linkage
FleetsideBill is offline   Reply With Quote
Old 04-04-2019, 10:51 PM   #4
BIGglaSS
BIGglaSS's Avatar
2010+ Camaro manifolds typically fit anything. Here's camaro manifolds with camaro front clip, to show you how they tuck up to the block.
My museum of good intentions: 1957 3100 BBW restomod -- 1981 swb -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 04-07-2019, 09:37 PM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
I used Corvette Z06 exhaust manifolds on my LQ4. They're good for over 500hp I've been told. No need to go through the gyrations it takes to fit many headers.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 04-08-2019, 01:47 PM   #6
akdg87
akdg87's Avatar
TBSS manifolds fit really tight to the block and should allow your steering linkage to work. I used a driverside one with my turbo kit and it fits awesome.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer lsx, lowered, 20" texas editions
akdg87 is offline   Reply With Quote
Old 04-13-2019, 08:34 PM   #7
jaws61
i used a set of speed-engineering with my truck with a mustang ii front end and got them to work, Had to cut off the passenger side 4l80e ear, The driver side is really close to the steering column but they look sweet, I'll let you know how they run in a month....
jaws61 is offline   Reply With Quote
Old 04-16-2019, 10:45 AM   #8
daveshilling
daveshilling's Avatar
I used Trailblazer SS (TBSS) Manifolds on mine, they fit really tight to the block and allow plenty of space for steering components. I have my engine mounted really tight to the firewall so I imagine that changes things a bit, but they still work really well.
My Trucks:
1958 Apache Extra Long Step Big Window "Lucky" build thread (by me)-Found a cheap truck to learn on
1959 Apache Short Step Big Window "Jackalope" build thread (By Delmo) - My dream truck
1959 GMC Fleetside BBW Factory V8 -- living the good life in the garage, hasn't really been touched
daveshilling is offline   Reply With Quote
Old 04-16-2019, 12:08 PM   #9
jwhotrod
I borrowed a set of C4 headers from Melrose corvettes in Cortland,IL to test fit on my ls3 build (55 chevy truck with Flat outs C4 suspension. They fit great. Come both uncoated and coated would be a great choice.
jwhotrod is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
