08-20-2019, 10:58 PM | #1 |
How the hell do you install this????
I am not having any luck installing this on the passenger side of my 72's bench seat. |
08-20-2019, 11:03 PM | #2 |
Re: How the hell do you install this????
Hard to do with the seat in the truck, basically slide the spring over the square seat latch bar, compress the spring, and install the Key into the slot and let the spring capture it.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
08-20-2019, 11:54 PM | #3 |
Yeah, it sounds so simple but it is a pain with the seats in the truck.
08-21-2019, 12:39 AM | #4 |
The Older Generation
Make sure that the key (square piece) is all the way out when you try to put it together. It is easier with 2 people. Push on the key from the inside of the track while you slide the seat back and forth a little. This will let the key slide all the way to the outside. Hold it in that position while you assemble the spring and keeper. This is next to impossible for one person to do with the seat installed..... I will include a couple of pictures of the parts with this post. The first picture of the parts assembled is looking at the bottom and the second picture is looking at the top. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 08-21-2019 at 11:31 AM. |
08-21-2019, 07:12 AM | #5 |
There was a You Tube video on this but the guy threw his camera and broke it before he got through it
08-21-2019, 08:04 AM | #6 |
Can you zip tie the spring in place and then cut it off after getting it on
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
08-21-2019, 08:17 AM | #7 |
maybe a stupid question, but how does it work? how do you move it in order to slide the seat?
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
08-21-2019, 08:28 AM | #8 |
You compress the spring (freeing the détentes) using the handle on the other side as a lever.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
08-21-2019, 11:22 AM | #9 | |
There are pictures in this thread that will give you some idea. http://67-72chevytrucks.com/vboard/s...d.php?t=418802 LockDoc
08-21-2019, 08:44 PM | #10 | |
Thanks! |
08-21-2019, 11:24 PM | #11 | |
No problem. Let us know how it goes for you. LockDoc
