09-22-2018, 04:25 PM | #1 |
all fuses hot with battery hooked up 65 c10
I am almost done with my 65 restoration so today I put a battery on it to check out the wiring and all the fuses are hot like the switch is on. So I unplugged the switch and the same thing. All the wires coming to the switch are hot except the one going to the start side of the starter. What do I need to check. This is a 1965 c10
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
09-22-2018, 08:16 PM | #2 |
Re: all fuses hot with battery hooked up 65 c10
And what have you done with the wiring during the restoration?
09-22-2018, 08:37 PM | #3 |
Nothing it was set aside then retaped and reused. I thought maybe the switch was bad but I unplugged it with the same result. I unplugged the harness at the firewall and 2 of the 5 wires where hot
09-23-2018, 09:49 AM | #4 |
any one have a picture of the horn relay, voltage regulator wiring on there 64-66
09-23-2018, 06:16 PM | #5 |
found a wire someone had added for some reason and cut it now all works like it should
