Old 10-28-2017, 09:21 AM   #1
dennislbrooks
dennislbrooks's Avatar
2 3/4 to 2 inch rear brakes
Will the 1967 12 bolt 2" brakes drums, 2" shoes, and backing plates fit/work on a 1985 k10 GM 10 bolt rear axle that now has 2 3/4" brakes on it?
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 10-28-2017, 09:53 AM   #2
Bigdav160
Bigdav160's Avatar
Re: 2 3/4 to 2 inch rear brakes
I am going to guess that it would bolt up fine with the exception of the brake drum. The axle flange is going to extend out further and you need a wide drum to cover that space.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-28-2017, 11:04 AM   #3
randy500
THe brakes will interchange. The wider brakes take a specific backing plate so if you change the backing plate it will work. I have done it many times on square body trucks, on those they can have either 2” or 2 3/4” brakes. The brake cables will probably be different but those interchange too. So install the backing plates complete and use the old brake cables then it will all work.
randy500 is offline   Reply With Quote
Old 10-28-2017, 11:07 AM   #4
randy500
Axle flange stick out from rear end housing is called “brake spacing” it is generally a set distance based on rear end type and manufacturer, when there are different width or diameter of brakes the backing plate is offset to make up the difference.
Old 10-28-2017, 03:27 PM   #5
dennislbrooks
Thanks Bigday160 and Randy500. Worked fine ----Tried it today and if not an exact fit it is very close.
