Old 01-02-2019, 02:35 PM   #1
JR1
Radiator heater hose fitting
Hello, working on 75 blazer, dont think radiator is stock, on passenger side from top down it has filler neck and cap, then overflow hose, then a heater hose fitting, the fitting appears to be plastic and screw into radiator then hose clamps on that, the plastic fitting is leaking, im hopping I can get a new fitting, not a new radiator, anybody seen this, i asked at oriellys and two shops, they didn't know, they didn't seem to sharp though. Below those three things are two transmission cooler lines, and then the main radiator hose!
Last edited by JR1; 01-02-2019 at 03:38 PM. Reason: I would also like to post the question on the truck board
JR1 is offline   Reply With Quote
Old 01-02-2019, 04:23 PM   #2
jaros44sr
jaros44sr's Avatar
Re: Radiator heater hose fitting
I would clean the area(sanding) around the fitting, look for cracks. Take out the fitting and check the threads, reinstall with a brass fitting of the correct size and thread sealer(perm a tex), then make sure the hose is supported in some fashion
If it is cracked, time for a radiator shop, or try to soldier it yourself, but I suspect the plastic threads gave out
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-02-2019, 05:16 PM   #3
JR1
Thank you, the fitting itself is cracking between threads and where the hose clamps on, where would I get a fitting this size? This seems like a common part but nobody seems to know about it.
Old 01-02-2019, 06:44 PM   #4
jaros44sr
jaros44sr's Avatar
You could start at Jeg's, pretty common fitting in NPT with barbed end. about 28 pages of fittings
what size is it? I have extras laying around
SAFETY FIRST
AS usual, off topic
Jim
Old 01-02-2019, 06:52 PM   #5
JR1
Dont know, thought it might break if I took it off, since it's a very slow leak I thought I would wait till I found a part before taking it out, since you seen to think I'll be able to get one I'll take it out and measure it! What is it called at jegs?
Old 01-02-2019, 06:57 PM   #6
JR1
Btw what's NPT
Old 01-02-2019, 07:46 PM   #7
simicrintz
Originally Posted by JR1 View Post
Btw what's NPT
Google is your friend
National Pipe Thread Taper (NPT) is a U.S. standard for tapered threads used on threaded pipes and fittings. In contrast to straight threads that are found on a bolt, a taper thread will pull tight and therefore make a fluid-tight seal."
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 01-02-2019, 07:50 PM   #8
JR1
Awesome, thanks, I'll pull the part and measure, I know the hose end is for 5/8 inch hose, just gotta measure the thread end, from looking at jegs, 1/2 is most common, so I'm guessing that!
Old 01-02-2019, 10:41 PM   #9
jaros44sr
jaros44sr's Avatar
BTW, buy yourself a thread gauge, it will tell you how many threads per inch.
also try to buy a brass fitting, incase you have to solder the fitting to the tank.
Is your radiator brass?
p/n 984010 is earls in aluminum, but there are angled ones that may help for hose placement
SAFETY FIRST
AS usual, off topic
Jim
Old 01-02-2019, 10:47 PM   #10
JR1
Thanks, maybe it is brass, its just a basic radiator, id eventually like to go aluminiun. Im supposed to be learning all this but life keeps getting in the way
Old 01-02-2019, 10:49 PM   #11
jaros44sr
jaros44sr's Avatar
or NPS, national pipe straight
SAFETY FIRST
AS usual, off topic
Jim
Old 01-02-2019, 10:53 PM   #12
jaros44sr
jaros44sr's Avatar
Life always gets in the way, I'm laid up with muscle spasms right now or I'd be working on my truck...1 hour heating pad and 1 hour of ice bag plus pain meds
Glad I have the motor trend channel to keep me entertained
SAFETY FIRST
AS usual, off topic
Jim
Old 01-02-2019, 11:17 PM   #13
JR1
Wow, now I feel bad for even joking, I hope you get better!
Old 01-03-2019, 10:04 AM   #14
jaros44sr
jaros44sr's Avatar
No problem, getting old sucks, but it sure beats the alternative LOL
Let me know how you make out with the fitting
SAFETY FIRST
AS usual, off topic
Jim
Old 01-03-2019, 12:23 PM   #15
rpmerf
rpmerf's Avatar
Home Depot, Lowes, whatever tend to carry brass barb fitting. They usually even have things there to help find the thread. You want your barb size to be 5/8", you can use the display to find your thread. Go for brass rather than plastic.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 01-03-2019, 02:12 PM   #16
JR1
Thanks guys, I have a home depot list anyway, ( who doesnt). I notice you truck listed, u also have a 69, CAP custom camper longhorn 350 th400.
Old 01-03-2019, 02:28 PM   #17
JR1
Dang auto correct, I have a 69 c20 custom camper longhorn 350/400
Old 01-03-2019, 09:50 PM   #18
rsavage
rsavage's Avatar
Nice rig. I had a 71 c30 longhorn with a 402 TH400. Single rear. Had a big camper like yours an pulled my boat withit at the same time. Had a step bumper with 2X2" square tube so I could extend the bumper beyond the camper. In a moment of stupidity, I sold it years ago.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-03-2019, 10:14 PM   #19
JR1
Well, it seems we humans get bored with stuff fir sure! I took this apart, its in the yard disintegrating until i freakout and cant believe i did that, then FIX IT UP AGAIN! It needs a more powerful motor! For SAFETY reasons of course!
Old 01-04-2019, 08:59 AM   #20
rpmerf
rpmerf's Avatar
Nice truck! I love seeing old truck still working. That's an impressive load it's hauling.
I dig the buggie too. My father has has a 73 VW Thing since before I was born. I learned to drive stick in that Thing.
1997 GMC Suburban
Old 01-04-2019, 01:29 PM   #21
JR1
Thanks, the c20 longhorn handles the weight fine, the 350 motor complains the whole time But made it to the desert and back a few times, SO VINTAGE ITS FUN, camper is a 1971 vista Liner!
Old 01-04-2019, 08:13 PM   #22
simicrintz
Those bikes look like they are BLUE!!! Don't you know real bikes are red and orange
OW? Superstition? Where are you at?
-Bruce
1971 K5 Blazer 4WD
Old 01-04-2019, 08:20 PM   #23
JR1
South of OW, fish creek old mine road area
Old 01-04-2019, 08:56 PM   #24
simicrintz
Very cool! WR's? What size?
-Bruce
1971 K5 Blazer 4WD
Old 01-04-2019, 10:01 PM   #25
JR1
Old yz250 's, 2002, good bikes, WE SUCK THOUGH! BUT LOVE THE DESERT
