07-22-2019, 02:59 AM | #1 |
Gas Tank Removal Safety Tips Please
I have a first-gen Camaro gas tank in the rear of my panel and for some unknown reason I run out of gas at 1/4 full on the gauge. So I need to drop the tank to access the sender to see what's the problem. Any safety suggestions for removing a tank full of fumes?
1951 Chevy Panel Truck |
07-22-2019, 03:36 AM | #2 |
Re: Gas Tank Removal Safety Tips Please
Ive use a high temp 3m 433 silver tape over the fill tube when I pull mine out...mostly just to keep gas from spilling in the shop floor..works for fumes as well
and don't do it in a closed shop...have a fire extinguisher handy as well you may just need to adjust your float..does it read over full also?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 07-22-2019 at 03:44 AM. |
07-22-2019, 10:31 PM | #3 |
just use a floor jack
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-23-2019, 01:49 AM | #4 | |
Will do.
07-23-2019, 03:25 PM | #5 |
It my be the ohms of the gauge vs the ohms of the sending unit.
I think the truck stock gauge is 0-30 and the Camaro sending unit is 0-90. If that's not the problem than an adjustment to the float should fix it.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
07-23-2019, 06:39 PM | #6 |
Do it logically. Find out how many gallon tank you have. Drain the tank (as much as possible), measure the ohms, add 5 gallons, measure the ohms, 5 more gallons, measure again. See where your gauge reads at each filling, then you can tell how far off the gauge is to the actual amount in your tank. Removing the tank should be the last resort.
07-24-2019, 03:20 AM | #7 |
Carry a gallon of gas with you drive it until you know it is out of gas, put enough in to get back home and then pull the EMPTY tank. I don't know how many tanks I pulled that some idiot had stopped at a station on the way to the shop and filled the tank when I worked in a Pontiac dealership in Texas and for some reason gas tanks were on my job list.
Don't smoke while pulling it and don't use an old school drop light with an incandescent bulb. A floor jack or transmission jack or even a motorcycle jack works pretty good to save dropping it on yourself. Check the range of the sending unit with the sender out of the tank and grounded to the truck with the wire to the gage hooked up.
