Old 01-27-2018, 06:05 PM   #1
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool 1972 c/30 bb longhorn
Here is the start of my Longhorn rebuid/restore.
This is a complete bumper to bumper original unmolested truck.
Its time to do her!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 01-27-2018, 06:09 PM   #2
RPOZ11
RPOZ11's Avatar
Re: 1972 c/30 bb longhorn
Started with taking off the original Quadrajet for rebuilding :
7042206 QA
Pulled the original points distributor out:
1112064
HO72 build :
2017 SS
Old 01-27-2018, 06:12 PM   #3
RPOZ11
RPOZ11's Avatar
Cool Re: 1972 c/30 bb longhorn
Will now begin on the brake system :
Rotor original ID code : GX
HO72 build :
2017 SS
Old 01-27-2018, 10:37 PM   #4
RPOZ11
RPOZ11's Avatar
Pulled the original calipers off and put on a set of rebuilt ones for the time being until I can get them SS sleeved; along with the original M/C.
Got the system pressurized up front.
Now onto the rears.
HO72 build :
2017 SS
Old 01-27-2018, 10:41 PM   #5
RPOZ11
RPOZ11's Avatar
Rear axle
HO72 build :
2017 SS
Old 01-27-2018, 11:23 PM   #6
RPOZ11
RPOZ11's Avatar
Another undercarriage image....
HO72 build :
2017 SS
Old 01-27-2018, 11:35 PM   #7
RPOZ11
RPOZ11's Avatar
Big Brakes
HO72 build :
2017 SS
Old 01-28-2018, 01:25 AM   #8
68bowtie
68bowtie's Avatar
Oh wow. Super cool. Subscribed! Any other pictures of the truck or the SPID? What are the plans?
"if a job's worth doing, it's worth doing well"
Project "C10 Fever" (68 factory black 396 swb):
http://67-72chevytrucks.com/vboard/s...d.php?t=686732
Project "Blue Bomb" (rebirth of a 1970 c30):
http://67-72chevytrucks.com/vboard/s...d.php?t=770878
Old 01-28-2018, 01:48 AM   #9
lolife99
Old Member
lolife99's Avatar
Subscribing,
Keith
Convert to disc brakes.
WTB: Radio Delete Plates and clips.
Old 01-28-2018, 02:04 PM   #10
RPOZ11
RPOZ11's Avatar
I think the SPID is gone; last i looked.
will look again.
Plans:
I will remove the original 402 engine and T-400 and install a 496 i just had done.
Rebuild an extra T-400 I have and add a GearVendor to it.
I'm going to pull the HO72 in it and rebuild that at a later date.
I have a 14-Bolt 3:42 Posi rear to install into it.
Just waiting on the leaf & shock mounts to be relocated on it.
Otherwise I am going go thru everything on it.
HO72 build :
2017 SS
Old 01-28-2018, 10:52 PM   #11
RPOZ11
RPOZ11's Avatar
Got into the left rear brake.
Wheel cylinder was locked up.
Disassembled & did a simple clean up.
Last image simple rebuild...
Here is the drum :
HO72 build :
2017 SS
Old 01-31-2018, 10:04 PM   #12
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice Longhorn! I have one in my garage right now that is probably close to the same as yours. It is a pretty optioned up C30 Super too. Here's a pic of the spid.
Ryan
1976 K30 CC SWB Build Thread
Old 02-01-2018, 02:55 AM   #13
RPOZ11
RPOZ11's Avatar
Nice!
Wish mine was a bucket seat truck.
This will be a slow rebuild
But each weekend we will get after it
HO72 build :
2017 SS
Old 02-01-2018, 10:29 AM   #14
RPOZ11
RPOZ11's Avatar
Anyone have any idea how many Longhorn trucks were assembled as C 30 builds?
HO72 build :
2017 SS
Old 02-01-2018, 07:40 PM   #15
Dieselwrencher
2450 in fleet side C30 Longhorn in 1972.
http://outintheshop.com/prodnum.html
Ryan
Old 02-04-2018, 12:01 AM   #16
RPOZ11
RPOZ11's Avatar
Cool
Thanx
But like everything;
a breakdown of vehicles optioned would be ideal and difficult to provide.
Nice resource
HO72 build :
2017 SS
Old 02-04-2018, 12:05 AM   #17
RPOZ11
RPOZ11's Avatar
I got into the right rear brake.
I'm going to need to find a replacement drum as it was scored badly beyond usable.
The wheel cylinder on this side was leaking.
Need to locate a replacement spring for the top bar below the wheel cylinder.
It broke as I removed it.
That's it for today
HO72 build :
2017 SS
Old 02-04-2018, 01:42 AM   #18
Dieselwrencher
I have 1 ho52 that is for parts. I could pull it apart and check it out for ya.
Ryan
Old 02-04-2018, 03:24 PM   #19
RPOZ11
RPOZ11's Avatar
OK, COOL... THANX
HO72 build :
2017 SS
Old 02-04-2018, 05:14 PM   #20
RPOZ11
RPOZ11's Avatar
Id like to locate some original pins with the raised 1 that are mint, undamaged, & straight.
Here is also a pic of the springs I need...
HO72 build :
2017 SS
Old 02-06-2018, 12:07 AM   #21
Dieselwrencher
I'll work on getting it dug out and getting the hub off as soon as I can.
Ryan
Old 02-06-2018, 02:26 AM   #22
RPOZ11
RPOZ11's Avatar
All good here
No rush
I found a 12" drum but I'm still digging for a 13" one.
All this takes time
HO72 build :
2017 SS
Old 02-10-2018, 08:13 PM   #23
RPOZ11
RPOZ11's Avatar
OK...
So I'm looking for a replacement 1972 issue GM 13" rear brake drum.
Part # 48716 is present in the 1972 drum; actually shows ---> 48716 4.
Here, in the pic below , is a comparison between the 1972 drum on the right and the 14-Bolt 13" drum on the left.
Both use the same shoe width.
The 14-Bolt drum is thicker where the hub is installed; maybe by approx 1/8".
The backing plates are identical except for where the pin goes thru.
We are going to try to install the 14-Bolt drum with the 1972 hub installed and see if it can be used.
The original 1972 backing plate is currently installed for this trial install.
HO72 build :
2017 SS
Old 02-10-2018, 09:02 PM   #24
RPOZ11
RPOZ11's Avatar
14-Bolt drum installed with shoes in place...
It fits without hitting anything
Factory studs are too short with the thicker drum
HO72 build :
2017 SS
Old 02-11-2018, 01:23 PM   #25
RPOZ11
RPOZ11's Avatar
While I am awaiting for some of the new replacement brake parts to arrive,
I decided next to remove the driveshaft assembly.
I don't recall ever seeing these before on prior trucks, but at the carrier bearing, the securing bolts have a bolt with a drilled hole into then using a slide pin as shown :
HO72 build :
2017 SS
Copyright ©2000 - 2018, vBulletin Solutions Inc.
