Old 02-12-2018, 09:46 AM   #126
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Originally Posted by hewittca View Post
Nice to see an update. The raised steel floor looks great! Did you have to cut the lip off the edge of the steel floor to get it to slide up between the bedsides like that? When I did mine, I ended up moving the mounting flange up the sides of the bedsides like they are connected stock because I thought the bed floor wouldn't fit and I didn't want to cut off that lip. I'm thinking now maybe I could have done it this way afterall.
Nope, I had no issues with it. I would have liked to do that but it seemed like more work and I didn't want to put back in all the carriage bolts.
Phill
68 Anniversary build - LS swap & Porterbuilt
Instagram @fourdoorphill
Phill0406 is offline   Reply With Quote
Old 02-19-2018, 02:57 PM   #127
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Got the motor freshened up. LQ4 with an LS6 intake, holley EFI fuel rails, AN-4 steamline fittings, F body water pump, low mount f body alternator, high mount F body power steering and dirty dingo spacers to maintain the truck crank pulley (which desperately needs to be painted or replaced). Still need to get a new set of valve covers - will likely end up with the small block script covers. Waiting on the power steering pulley and tensioner too. Nervous the orange and black will look weird with a gold firewall but we shall see. I wish I could have just kept the three piece vortec cover and avoided this whole expense but it didn't fit with the cover on. Oh well.
Before and after
Phill
Old 02-19-2018, 04:11 PM   #128
gringoloco
A guy with a truck
gringoloco's Avatar
Re: C10 Goldilocks
No worries, that shade of orange goes with everything
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass
gringoloco is offline   Reply With Quote
Old 02-19-2018, 04:18 PM   #129
khess
Junior Member
khess's Avatar
Re: C10 Goldilocks
This is awesome. Just read through the whole build.
khess is offline   Reply With Quote
Old 02-19-2018, 04:46 PM   #130
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Much better than a blue, don't ya think
Should be okay because the side markers and tail lights are orange and red and look fine against the gold - I figure the Chevy Orange is just kinda a blend of the two.
Thanks man!
Phill
Old 02-21-2018, 10:39 AM   #131
khess
Junior Member
khess's Avatar
Re: C10 Goldilocks
Mind me asking what the wheel/tire set up is ?
Old 02-21-2018, 10:41 AM   #132
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Of course not. 15x5 3.75BS and 15x10 4.5BS with 235/70/15 and 275/60/15.
They're wheel vintique wheels with diamonback classic wide whites.
Phill
Old 02-21-2018, 10:45 AM   #133
khess
Junior Member
khess's Avatar
Re: C10 Goldilocks
Thank you sir ! Everyone usually runs larger wheels lol Figured I'd ask.
Old 02-21-2018, 10:46 AM   #134
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
I went back and fourth with running a big wheel or not, ultimately it came down to satisfying an itch I always had for white walls. Maybe I'll switch it up one day but I love this look.
Phill
Old 02-21-2018, 10:57 AM   #135
khess
Junior Member
khess's Avatar
Re: C10 Goldilocks
It's an awesome look. I asked if you minded since I come from the subaru / lowered car crowd and everything is a secret lol I'm sure you know this.
Old 02-21-2018, 11:01 AM   #136
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Worst part of the car culture is how everyone thinks they invented it. You'll enjoy the c10 community much much more.
Phill
Old 02-21-2018, 11:02 AM   #137
khess
Junior Member
khess's Avatar
Re: C10 Goldilocks
Amen to that !
Old 02-21-2018, 04:21 PM   #138
knomadd
knomadd's Avatar
Re: C10 Goldilocks
Looks good! Here's an idea for you.. keep what you have and just add some holley coil covers, painted to resemble the sbc script covers, but a big block size. Here's what mine looks like now.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-21-2018, 08:27 PM   #139
Orange67
Orange67's Avatar
Re: C10 Goldilocks
I love this build, and yeah that color goes good with anything. It will be stunning!
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 02-21-2018, 11:07 PM   #140
KevinK7
KevinK7's Avatar
Re: C10 Goldilocks
What a cool build, the truck looks awsome ...great job
KevinK7 is offline   Reply With Quote
Old 02-22-2018, 08:30 AM   #141
builtbyKane
builtbyKane's Avatar
Re: C10 Goldilocks
The motor turned out very clean. I'm sure it will look great under the hood.
builtbyKane is offline   Reply With Quote
Old 04-26-2018, 09:57 AM   #142
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
More progress. Finished shaving the firewall - there were still a few small holes I needed to weld up, also added three holes in the center, two for the coils and one for the main harness. I also put some body filler on it to get it laser straight as before i just seam sealed it and called it good. Had a buddy come and shoot some PPG 23048 which is the anniversay gold. It matches real well. Took 7 coats to cover though as it's a very translucent paint. Got the motor back in with some small block valve cover adapters. Got a PSI harness to replace the OEM one I had and she's back to running 3 months later. Instead of running pigtails off the coil park harness I unpinned the plug, unloomed the harness, pulled it all back before the firewall grommet, added a ground and repinned everything. That way I don't have a wire going out of the cab just to come back in. I used ICT coil mounts and put them underneath the rain tray and siliconed the holes from the top side. Made the wires to length using some ceramic boots and high temp wires. Had to move the alternator from the lower driverside position to upper passenger side because it hit the steering rack. Finally got around to mounting the hood with the porterbuilt hinges. Still need to do a few small brake lines, bleed the MC and brakes, adjust the shift column linkage (doesn't go lower than drive currently) and some other small things like figure out coolant hoses. It's the little things that slow you down.
I really love how clean the engine bay is - for now atleast. I desperately want to get some Hills inner fenders and I want to make a cover for the chassis wiring on the drivers side. I'll also get around to splitting the alternator and having the casing powder coated black. It looks like crap with the OEM silver.
Phill
Old 04-26-2018, 08:27 PM   #143
rusty76
rusty76's Avatar
Re: C10 Goldilocks
Looks killer.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-26-2018, 08:41 PM   #144
Mikem_72
Re: C10 Goldilocks
Man that's some beautiful work. I love everything about this truck.
-Mike
1970 C10 Stepside 350/700r4
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632707
Mikem_72 is offline   Reply With Quote
Old 04-26-2018, 09:10 PM   #145
KevinK7
KevinK7's Avatar
Re: C10 Goldilocks
Those valve (I mean coilpack covers look awsome
Love it !
Old 04-27-2018, 08:06 AM   #146
Bennett68C10
Bennett68C10's Avatar
Re: C10 Goldilocks
Very nice!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-27-2018, 01:22 PM   #147
Phill0406
Phill0406's Avatar
Re: C10 Goldilocks
Thanks everyone - feeling pretty happy with it. Just wish i didn't have to cover up the frame and engine bay with a crusty body hah. No plans to paint it for now at least.
Phill
Old 04-28-2018, 11:38 PM   #148
milner
milner's Avatar
Re: C10 Goldilocks
I wouldn't paint it, looks perfect the way it is!
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi.
milner is offline   Reply With Quote
Old 05-02-2018, 04:41 AM   #149
MQUnlimited
MQUnlimited's Avatar
Re: C10 Goldilocks
Amazing build. Read the entire thing and has me antsy to work on my 68 as well. I come from open desert off-roading so this "low-life" C10 scene is completely alien to me but already loving it.
MQUnlimited is online now   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
