08-24-2010, 03:10 PM | #1 |
Door stop bracket
Anyone know of a vendor that sells the door frame bracket for the door stops for a 63 truck, I checked the usual suspects and no luck, the pick and pull here only has the 64 or later cabs, Thanks in advance. Larry
08-24-2010, 04:13 PM | #2 |
Re: Door stop bracket
I think I got mine from ether Classic Industries or LMC. But I might be thinking of the wrong part. Do you have a pic?
08-24-2010, 04:56 PM | #3 |
I'll look through the pic's tonight and post one it's the part that goes on the door frame not in the door, which is usually what they sell, more later, larry
08-24-2010, 06:54 PM | #4 |
is there a difference between 63-64
ron truck and car shop part nbr. 60-02504 fits from 60-66 Last edited by padresag; 08-24-2010 at 07:01 PM. |
08-24-2010, 07:20 PM | #5 |
I looked at the pick and pull and the one's on the 65 up pickups they had there were differen't, I do not have a pic so I may need to post when I get home later this week, I included a pic of the door piece, the one I need is pinned to the end of this one, Larry
08-24-2010, 07:32 PM | #6 |
they are all the same. someone may have put something else on there. some jeep rear door ones work
one fits all ron |
08-24-2010, 07:50 PM | #7 |
1961 crewcab
60-63 the bracket was screwed to the cab, 456 it is welded on.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-24-2010, 07:53 PM | #8 |
1961 crewcab
I don't know how far a drive whitehall is from you , but neill freman has a few 60-63 trucks in his yard.
08-24-2010, 07:58 PM | #9 |
I am in Butte this week so White Hall is across the hill, I'll look him up in the directory and see what he has, thanks, Larry
08-24-2010, 07:58 PM | #10 |
the only difference then is the attachment to the pillar, but not to the stop mechanism itself
ron If one needs the part the screws onto the pillar,I do have a cab that I am getting rid of this week that has them on, 62 |
08-24-2010, 08:30 PM | #11 |
Not sure if the `63 is the same but I think it is, go here
http://67-72chevytrucks.com/vboard/s...ep+door+checks
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
08-24-2010, 09:20 PM | #12 |
"If one needs the part the screws onto the pillar,I do have a cab that I am getting rid of this week that has them on, 62 "
I'll call Niel tomorrow when his yard is open, if he dosen't have them I'll shoot you a PM tomorrow, thanks for the offer, Larry Last edited by brew8; 08-24-2010 at 09:21 PM. |
08-24-2010, 10:40 PM | #13 |
Senior Enthusiast
I found an NOS pair on eBay. If the oem part number does you any good, here's a photo showing the items and the id tag. The original part number is 3773478. I do not believe these are being reproduced, only NOS or used.
07-23-2019, 12:55 PM | #15 |
64 Door stop bracket
Where can I buy this door stop for my 1964 C10?
07-23-2019, 01:14 PM | #16 |
Re: 64 Door stop bracket
I think most of the big retailers sell them. Classic industries, LMC, Classic trucks of America and brothers.
I used a set of jeep cherokee door stops they work grate and have notches so you can keep them open at different positions. I will try to find the tread on it or you can do a search on here for jeep cherokee |
07-23-2019, 01:25 PM | #17 |
I bought a pair of aftermarket door checks, they were so weak that a small gust of wind would slam the door.
I found NOS ones, kinda pricey but they hold the door open even in strong winds. next time i need door checks i will get the jeep ones, they sound like an improvement over originals and a lot cheaper price.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
07-23-2019, 02:01 PM | #18 |
here is the link to the thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446066 |
07-23-2019, 02:45 PM | #19 | |
But Found Her 25yrs Later!
07-24-2019, 01:58 PM | #20 |
Moderator
07-24-2019, 04:45 PM | #21 |
I got the front ones they have too indents and if you cut the rubber bumper in half the door will open as wide as originally
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
07-26-2019, 07:20 PM | #22 |
Wow 22 for a door stop. Brothers , Car and truck shop.
07-26-2019, 07:22 PM | #23 |
Moderator
Ya and theyre worth all of $5.
08-01-2019, 02:14 PM | #24 |
08-03-2019, 07:03 PM | #25 |
Hello
Does anyone know where to get door stop screws at? Thanks Pete |
