Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 07-13-2013, 04:45 PM   #101
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 46 pickemup in NJ "the Rebuild"
Wow. No one will ever accuse you of living in the hood. That's some place.
Tx Firefighter is offline   Reply With Quote
Old 09-26-2013, 07:48 PM   #102
paintman
Ok guys, I'm back! sorry for the lack of updates but this has been the Summer from hell around the Paintman's place. As most of you know from my perevious posts, the wife and I had a patio installed off the back of our house which severely curtailed me from working on the 46.
To save money we didn't have our patio crew put our yard back together. that meant the paintman had to do a lot of grunt work during the summer months. Unfortunately, moving 15 ton of red dress stone, and 20 ton of top soil, with a nothing but a shovel and wheel, is a recipe for for being laid up for about 2 weeks with some serious back issues. And of course after recuperating from my back problems I had to throw in a visit to the emergency room for a bout of diverticulitis.
but it looks as if all those issues are behind me and the patio is completely done and I can get back to the 46.
Sausage and peppers anyone????
paintman is offline   Reply With Quote
Old 09-26-2013, 07:54 PM   #103
paintman
Ok so this is how the paintman gets his motor into the back of his wife's car when he's to cheap to buy or rent an engine hoist, and doesn't want to ask his next door neighbor if he can borrow his.
Two 2x12's and a big push and up it goes!!!!!
Old 09-26-2013, 08:02 PM   #104
paintman
Ok guys so here's a brain teaser...........What do you get when you add together....................
A motor and a bunch of parts in the back of the Wife's car +
A trip to Mystic Connecticut leaving first thing Friday morning +
And a room reserved for Friday and Saturday night at Mohegan Sun Casino in Uncasville Connecticut?
A free ata boy to the first one who answers correctly. Stay tuned!
Old 09-27-2013, 08:34 AM   #105
Cape Codder
Cape Codder's Avatar
For me it would be grief except Mohegan Sun might cancel out some of that. I would be at the Seaport while she would be at the casino.
Cape Codder is offline   Reply With Quote
Old 09-27-2013, 01:38 PM   #106
faribran
Lucky
faribran is offline   Reply With Quote
Old 09-29-2013, 06:18 PM   #107
paintman
And the answer is.......A Trip to Larry's Power to drop off the 292 for a total makeover. These are the same guys that did the infamous 292, spliced V8 hybrid head, for Leo Santucci's drag car.
Here's a pic of the team that will give the ole girl a face lift. On the far left is the owner Gary who bought the business from his former boss. And standing next to him is the guy (Steve? I think) who did most of the work on the spliced head for Santucci. And of course the rest of the team on the right. Some how a big dopey looking guy got his ugly mug in the pic on the far right.
Old 09-30-2013, 09:23 PM   #108
paintman
Ok, so another major piece of the puzzle arrived today in a Big Brown truck. As I mentioned earlier, I don't have a lot of the major fabrication tools for this kind of job, and that was causing me to have troubles closing in the firewall. To do it properly and not look like a total hack job would have meant either buying, borrowing, or renting a sheet metal break.
Fortunately for me Justin and the guys out at Scott's Hot rods were nice enough to put a box together for me exactly the way i wanted it. There's no way I could have put something like this together even if I had the right equipment. The damn thing is first class quality.
So the first thing I had to do was cut the opening in the firewall to accept the box portion. The plan is once I have that where it needs to be I will then trace around the flange portion so I know where the final cuts needs to be. Then it's just a matter of connecting it to the floor boards and stitching it to the firewall.
Anybody know what this thing is mounted on the firewall? For the life of me I can't figure out what the hell its for. On the inside of the cab it has a small steel tube coming out of it. I am trying to decide if I should grind it off or just notch the flange and work around it.
Old 09-30-2013, 09:58 PM   #109
old yelr
That part you're wondering about is where the water that gets past the cowl vent would drain. I diverts the water back to the outside of the cab. If you don't plan on having that vent functional you could probably get rid of it.
old yelr is offline   Reply With Quote
Old 10-05-2013, 07:43 PM   #110
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
lookin good paintman. also worked all summer on my property.but did have a chance to enjoy some car shows and family time.lookin forward to more pics.chizzler
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 10-17-2013, 10:13 PM   #111
paintman
Sooo as I was sayin.......It's pretty self explanatory as to what the paintman has been up to. Most of you guys have been here, done that, got the t'shirt.
But just to refresh your memory , cut, weld, grind, burn through, cut, weld, grind, burn through. etc. etc.
Old 10-17-2013, 10:30 PM   #112
paintman
On some of the smaller holes, instead of trying to make small plugs, I just shoved a sheet rock screw into the hole as a backer and burner her shut.
Once I got my holes filled in, I fit and stitched the recess box in. I originally had planned on cutting the opening for the box to fit flush into the firewall and then weld the flange all the way around. But upon further review i realized to do it that way would have meant cutting into the ribs that were stamped into the firewall at the factory for re-reinforcement. That just seemed like it would cause more trouble then it was worth so I mounted the flange to the back side of the firewall. I now have it stitched and ground down on the front side, and plan on stitching on the backside as well. Hope that made sense. Maybe the pics will help.
I was able fold over some the extra material on the recess box and create a flange to add more support for the floor boards.
So at the end of a few long days this what the firewall looks like. I still have alot of clean up to do yet but i'm gettin there. Did I do it right????????? I don't have a clue. But I know a painter that's good working with spackle
Old 10-18-2013, 10:39 AM   #113
Scottshotrods
looking good
Justin
Scottshotrods is offline   Reply With Quote
Old 10-19-2013, 07:18 PM   #114
Cape Codder
Looking good ,I think mounting it from the inside was a good idea. looks better without fooling with the ribs. In the future to fill a small hole just hold or clamp a piece of brass or aluminum behind the hole and weld it up. A chunk of aluminum will absorb the heat and will not stick to the weld.
Old 10-31-2013, 12:58 PM   #115
paintman
Ok, so the last few days have been all about brakeology 101. When I bought the truck it had some kind of 1/2 a@% brake pedal assembly bolted up under the dash, with the master cylinder mounted to the firewall. Well that was fine when the truck had the small block in it. Unfortunately when I decided to switch over to the inline motor, I soon realized the brake booster, master cylinder, and carburetor, wanted to occupy the same space in the engine compartment. Soooo that meant moving the brake booster to under the cab. Of course I have already covered what troubles moving the brake booster to under the cab would cause with my exhaust
So any ways here is a pic of the butched up pedal assembly that I took out from under the dash. I only wish I had kept the brake pedal to show how boogered up it was, but unfortunately I have already taken it to the local scrapper. You can kind of see the shaft the pedal swung on and the brake light switch.
So with that gone I mounted your typical TCI frame mount booster and pedal assembly. I'm sure most all of you have seen this 1000 times. Only thing I did different was to not use the plate that bolted to the frame that came with the unit. Instead I opted to weld a piece of plate to the frame and bolt the pedal assembly in that way.
From the front.
So of course as most of you know having the brake cylinder under the cab poses the problem of how do you fill the master cylinder. Well, I didn't want to cut a trap door in the floor and have to peel back the carpet all the time so a quick call out to Justin at Scott's Hot Rods solved the problem. All you need is one of his trick remote fill canisters and a lid tapped for fittings on your master cylinder.
This trick little unit is drilled and tapped for fittings on the back and bottom so mounting possibilities are just about endless. Decisions decisions...., I kind of like the look of it mounted to the firewall with no signs of any hoses.
But hidden under the seat is pretty cool too....Hmmmmm what do you guys think?
With that done it was on to some kind of E-brake. I have been pondering where I wanted to put my handle for quite awhile and finally decided to do under dash. Reason being, the 46 cab is pretty narrow and I didn't want to clutter up the floor anymore then I already have by putting it next to the shifter. So again, most all you guys have seen this before, but I used a Lokar set up.
Installation was pretty straight forward. In fact I was able to use it just as it came out of the box. No cutting of the bracket at all. The only thing I had to do was make a small spacer out of some plate steel to make up about a 1/8 in length I needed.
The bracket comes 15" long and can be cut down in 1" increments to fit what ever distance you have between your dash and firewall.
Here's a pic showing the spacer plate I made to take up some slack.
Here's a couple of different shots showing how its mounted. If you look close you can see the spacer plate between the bracket and firewall. Once I do the final assembly on the truck I will move the handle and ratchet mechanism more forward towards the firewall to get it tucked further up under the dash.
So that is where i'm at as of now. Tonight it's take the girls out trick or treating and over the weekend start patching up the gas filler hole and the holes in the cab floor to keep the Queen Mary from sinking!
Old 11-04-2013, 09:14 PM   #116
CHIZZLER
CHIZZLER's Avatar
progress is looking good.
61-crew cab D-max
Old 11-15-2013, 06:45 PM   #117
paintman
Ok some good news............I just got word from the engine shop that all is well with my block, head and crank! For those that have not read my whole build thread. I was able to find a 292 on the cheap that supposedly had the bottom end completely rebuilt. Not being a person very trusting of others, I told the engine shop to do a complete tear down of the motor and check the other shops work. Well, after a thorough cleaning, shot peening and magnaflux, it turns out everything is perfectly fine.
The only thing is the motor just had a standard rebuild. So that will be addressed with a complete blueprint of the block and balancing of the bottom end. Next up for Larry's Power is doing all the head work including installation of the lumps, bigger valves, springs, push rods, port matching, and a mild polishing of the ports, roller rockers.
As far as work on the truck itself......I have been putting off one big problem that has been staring at me since I lowered the truck a bit with the drop spindles and 2" lowering blocks. That's the fact that now my fenders are a bit to close to the rear tires. Typical story of change one thing and then realize you now have 3-4 other things to change. Well I had a few different solutions.
1. Find a smaller rear end
2. Larger wheel offset
3. Widen the fenders
4. Ding Ding Ding.........Raise the fenders!
So that's what I am in the process of doing. That is after I finish blowing the mountains of leaves I have off my property .
Old 11-22-2013, 08:00 AM   #118
chevy88
chevy88's Avatar
Really like how this truck is coming along, enjoyed reading this build.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 11-23-2013, 07:25 PM   #119
paintman
OK so after blowing enough leaves to fill 100 dump trucks, I finally got some extra time to get my fenders remounted. I didn't need to move them a lot, only about 1 1/2", but i think that should be enough.
Here's how she sits now, Probably the last time she will see the outside for awhile.
Here's a pic showing how much I raised the holes.
So I think that is it as far as the mock up goes. Next up its off to Home Repot for some wood and wheels to build a dolly for the cab. So I guess the next pics you will see is a bare frame headed off to the sand blasters.
Old 11-23-2013, 09:19 PM   #120
Cape Codder
I like the way the truck sits as I am a little to old school for the dropped to the ground look. I am a little concerned about the distance between your axle and the frame. Have you jumped up and down the in the back to see if it's gonna hit? Love the truck and really like the 6 in a row.
Old 11-24-2013, 08:24 AM   #121
paintman
Cape' I hear what your saying. I think it is still a little to close for comfort. I think when I do the final assembly on the truck it will be good though. The plan is to shorten up on the lowering blocks a 1/2" and to go with another 1/2" of back spacing on the wheels. That will put the outer most part of the tire just inside the lip of the fender. Plus the fact that in the pics the shocks are off so I think its a little spongy right now.
Once I put everything back as planned it should be fine, This is just a truck for running slow for coffee and breakfast with the wife, my racing days are over. I like the look of a lowered truck but not with the wheels and tires tucked real tight up under the fenders. My cup of tea is to have the fender opening filled just out to the lip of the fender. Plus I didn't want to spend the cash on a different rear.
Old 11-24-2013, 04:18 PM   #122
paintman
Well that was about the easiest thing I have done with this truck so far!
Old 11-24-2013, 07:20 PM   #123
paintman
Any of you guys dropping in for a look see know if this heater can be run off of 12 volts or retro-ed with a different fan motor to run off of 12?
Old 11-24-2013, 11:09 PM   #124
Cape Codder
The easiest way is with a resistor to drop the voltage, such as a ballast resister used in the old Chryslers. I changed to a 12 volt motor years ago in a 50 Olds only to find I had opposite rotation when done. I ended up drilling the rivits out of the motor and swapping polarity inside the motor. I know you used to be able to buy some nice small round voltage resistors at part stores as the Chrysler ones are about 4 " long.
Old 12-06-2013, 07:45 PM   #125
paintman
OK so it looks as if the purchase of an old truck just to tinker around with on weekends has turned into a complete frame off semi-resto/rebuild.
I figured if the Egyptians could build trillion ton pyramids without a hoist then the Paintman could certainly get his cab off just as easily. After a little bit of trial and error this is what I came up with...............I just jacked up each corner a little at a time and blocked up the jack stands until I got it high enough to slide the cradle under. Keep it simple stupid.
This is when you start drinking
Sucess!!!!!!!!!!!!!
Now it's just a matter of welding up all the extra holes in the frame, disassemble, and then off to the sand blaster. I guess there's no turning back now.
