Old 03-29-2011, 10:54 PM   #1
brett3xx
Converting 2wd to 4x4 using 3/4 ton 4x4 frame?
I'm wanting to convert my 67 to 4x4. I found a complete 71 3/4 ton 4x4 truck on craigslist I may buy for the swap. Will there be any problems I'd run into using the 3/4 ton verses a 1/2 ton frame.
brett3xx is offline   Reply With Quote
Old 03-30-2011, 08:05 AM   #2
duallyjams
duallyjams's Avatar
Re: Converting 2wd to 4x4 using 3/4 ton 4x4 frame?
That is the easiest way to do it.Should go smoothly.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 03-30-2011, 09:05 AM   #3
JimmyFloyd
shouldn't be an issue. You should gain disc brakes on the front with this as well.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 03-30-2011, 02:07 PM   #4
brett3xx
Is there any difference between the 1/2 ton 4x4 frame and 3/4ton frame, I'm going to have to shorten the frame because it's lwb but that shouldn't be a problem
Old 03-30-2011, 06:15 PM   #5
Ridgeback
No difference in the frames until you get to one ton.
Ridgeback is offline   Reply With Quote
Old 04-07-2011, 02:36 PM   #6
O'skool 72GMC
O'skool 72GMC's Avatar
The difference you are going to find is the parking brake and low hump high hump.
Parking brakes are foot opereated on the 71
and the high humps are on 4x4 trucks
O'skool 72GMC is offline   Reply With Quote
Old 04-07-2011, 04:38 PM   #7
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
High humps are also in 2wd's. Any factory big block truck, or a 4 speed truck will have a high hump.
Ryan
1969 Chevy milk truck
Old 04-07-2011, 04:39 PM   #8
Dieselwrencher
That won't matter in the 4x4's because GM never built a 67-72 4x4 1 ton.
Ryan
Old 04-07-2011, 04:41 PM   #9
Dieselwrencher
On the 4x4's, the 1/2 tons and 3/4 tons have the same height and thickness when talking about the actual channel of the frame. You will be fine.
Ryan
