Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-29-2017, 11:32 PM   #201
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 1972 Medium Blue Highlander Blazer Resto
I broke out a few other NOS pieces: AIR pump, grommets for the valve covers, oil caps, and bolt for the t-case shifter. Electroplating of El Paso did a good job on the rechromed shifter (http://www.electroplatingelpaso.com). I've got the chrome caps that cover the exposed division bars for the vent windows out for rechrome at the moment.
Old 10-29-2017, 11:39 PM   #202
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I've been able to piece together the missing pieces for the CA emissions control that was original installed, which was most of it including manifolds, heat shroud, injection pipes, and this piece with the two hoses. Not sure what this piece (edit: diverter valve) is called but Im going to chase a better example and need to track down the gasket used to install it onto the pump.
Maybe corvette parts suppliers will have the gasket...
Old 11-01-2017, 09:00 PM   #203
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Spent yesterday sorting out all the engine brackets and associated replated hardware. Inching closer. On a whim I carted home a reman A6 AC compressor: the harness connections are at 2:00 but OEM is on 11:00 - may send the original compressor out for a rebuild.
Old 11-01-2017, 09:01 PM   #204
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Went with an internally regulated alternator. Resto mod I guess
Old 11-01-2017, 09:02 PM   #205
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Polished up the rubber hose to the carb spacer and used replated Oem tower clamps.
Old 11-01-2017, 09:09 PM   #206
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Plug heat shields were replated. The tranny inspection cover would not pop into place: I suspect the nose cone for the starter doesn't match OEM. Sigh...
Old 11-01-2017, 09:10 PM   #207
cericd
cericd's Avatar
Loooking Goood!
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 11-01-2017, 11:12 PM   #208
Arrington01
Arrington01's Avatar
Looks great as always.
Arrington01 is offline   Reply With Quote
Old 11-03-2017, 05:51 PM   #209
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Looks great Pete. Moving along nicely. Are you sticking to the stock trans or thinking about upgrading to the 700R4?
When I was on the highway yesterday I kind of wish I did the 700R4 swap. When cruising at 65 mph my RPM's are about 2800 with the stock 3.07 gears that mine came with. Maybe sometime down the road I'll update mine to a 700R4.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 11-03-2017, 08:23 PM   #210
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks guys. Mike, since the th350 was original to the truck it was rebuilt and is bolted into place. The 3.07 gears were replaced with 3.73s and I expect to run 33" tires. It's going to generate some rpms on the hwy! I've got a 700r4 in my my k20 w 4.10s and it cruises at speed nicely w low rpm.
Old 11-13-2017, 09:04 AM   #211
IronCanine
I'm trying....
IronCanine's Avatar
Gosh...I sure do hate it when I miss an email alert. So much I've missed since Halloween. Great progress Pete. This is a special build. I'm tempted to say "keep up the great work"...but for you that's the same as saying: " Keep Breathing." Looks great!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 11-27-2017, 02:49 AM   #212
NorthernMatthew
NorthernMatthew's Avatar
Very interesting thread Pete, all of yous (I know that's not a real word but I use it anyways!) are awesome Chevrolet folks!
NorthernMatthew is online now   Reply With Quote
Old 11-27-2017, 10:35 AM   #213
GPS1975
GPS1975's Avatar
This is going to be an excellent restoration, nice work.
GPS1975 is offline   Reply With Quote
Old 12-16-2017, 10:05 PM   #214
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Hey Pete when you get it done to your standards and ever need cash the Blazer should come in handy.
https://www.ebay.com/itm/1972-GMC-Ji...53.m1438.l2649
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-06-2018, 11:45 PM   #215
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Build is gaining steam since the holidays. Since my last post I've rebuilt the vent windows and pulled more parts off the shelf for assembly.
What a hassle the vent windows are to build. I sent the chrome trim for replating and made use of some nos pieces.
Old 02-06-2018, 11:46 PM   #216
DeadheadNM
Carpe manana
DeadheadNM's Avatar
But they turned out nice.
Old 02-06-2018, 11:52 PM   #217
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Doors and fenders on - AC box and misc other pieces ahead of the firewall.
Old 02-06-2018, 11:55 PM   #218
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I found this NOS heater core - had date of February 1972 on the box, which coincides with assembly month for this blazer.
Old 02-06-2018, 11:58 PM   #219
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The medium blue is growing on me - I can't wait to see it in the sun.
Old 02-07-2018, 12:06 AM   #220
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Underdash harness installed - plug and play M&H. I was able to source the following NOS components: switches for the dash, wiper motor w pump, ignition relay, ignition bezel, AC controller, ash tray, dash pad, defrost vents, AC center vent, cigarette lighter, and a glove box light.
I'll get better pics soon.
Old 02-07-2018, 12:07 AM   #221
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Old 02-07-2018, 12:12 AM   #222
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Greg with S/M Electrotech refurbished this truck FM for me and installed an aux coax jack. The underdash speaker is a working original. I placed some gaffers tape between the top of the chrome faceplate and the chassis - van radios had this and it reduces light bleeding through into the cab.
I'm using a NOS telescoping antenna correct for an AM radio: the fixed mast FM examples don't ever seem to clear a garage door.
Old 02-07-2018, 12:14 AM   #223
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Old 02-07-2018, 12:21 AM   #224
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Mice had chewed the foam rubber flapper from the inside of my duct assembly. I found this replacement with a 1968 date on the invoice. With all the dust I assume this sat for decades on a shelf in PA.
Old 02-07-2018, 12:35 AM   #225
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Board member FAA benny refurbished this AC box for me and did a POA conversion for R134. The original AC hoses have been exchanged but the OEM metal fittings were kept. The original brass nut is still in place on the suction hose.
