04-28-2015, 03:25 PM | #1 |
62 c/10 front suspension
Who can tell me a little about the front torsion bar suspension. I've messed with a lot of coil springs,but never torsion bars. I'm looking at dismantling this thing to bare frame, or not lol. Just don't want anything flying out in my face.
04-28-2015, 07:04 PM | #2 |
Who Me?
Re: 62 c/10 front suspension
Get your truck up off the ground. Loosen the bolts the adjust the tortion bars. I think they take a 15/16 socket. They should loosen up and take tension off to remove them.. The rear part of the bar just sits in a pocket and will come down when you take off the lower control arm off.
When I replaced my lower ball joints they came apart easy. If you plan to keep the bars, it will be kinda tricky to get them readjusted to keep the truck level. I kinda did that by eye.
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
04-28-2015, 09:04 PM | #3 |
Lots of penetrant I used WD40 new stuff, PB Blaster or the like. Tightening gets lift, loosening gets you lower. Support pork chops with jack and loosen bolt lower jack. It s like letting a spring down slowly. Use a big bar or punch to push bars out of arms. Rest is just bolts.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
04-28-2015, 09:18 PM | #4 |
X2...lots a lube before you dismantle anything.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
