03-25-2017, 07:55 PM | #1 |
Taillight issues 92 'Burb
I bought this 92 burb, the P.O. dragged it out of the woods so I plunked down my $600 and drove it home. The taillights were spastic, some times the signals and taillights worked sometimes they didn't. I bought NEW taillights because the sockets where the 1157 brake/turn/running lamps were had melted. These seldom worked either. I used L E D bulbs to hold down on the heat in the turn/running light sockets and in the back-up sockets. I finally found that the light assemblies weren't grounded, the trailer hitch wiring was bad so I removed it. Then everything worked but one of the LED's burned up inside so I had to order a new one and put a regular bulb in it temporarily. Today the other side LED running/brake light stopped working, and when I took the housing apart the other new LED had burned up and arced the housing socket badly.
Had anybody else run into taillights that melted the sockets, or has anybdy tried LED lamps and had them catastrophically fail? I mean they both burned, the second one looks like a used firecracker. Last edited by billnorman; 03-28-2017 at 10:48 PM. |
03-28-2017, 10:39 PM | #2 |
Re: Taillight issues 92 'Burb
had them get the sockets hot and melt. what brand were the LEDs? i would trace the wiring all the way to the fuse panel. chances are something else is messed up.
my tails act up when the ground is broken but not overheat.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
03-28-2017, 10:58 PM | #3 | |
I'm gonna add another ground wire to the Left side taillight tomorrow. I'm not going to put the LED's back in until after I get it inspected. |
