08-21-2018, 09:01 AM | #26 |
Re: Smooth Hood
Thanks for the info.
One final question - are we looking to achieve a complete end to end weld of the hood seam, or is it ok if is has many tacks along the way but the seam not welded completely end to end? Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
08-21-2018, 10:52 AM | #27 |
Re: Smooth Hood
Personally I'd weld it solid...also another tip is to get some heat sink putty....it'll help stop the heat from running out into the thin metal...
08-21-2018, 01:17 PM | #28 | |
Re: Smooth Hood
Wade
08-21-2018, 04:38 PM | #29 |
Re: Smooth Hood
A local on Craigslist is selling a brand new reproduction seamless AD hood for $200. Given all the work and potential problems of modifying an original, that sounds like a bargain.
1951 Chevy Panel Truck |
08-21-2018, 05:07 PM | #30 | |
Re: Smooth Hood
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
08-21-2018, 05:14 PM | #31 |
Re: Smooth Hood
I remember a episode of gas crackers where they tried to make one of those aftermarket smooth hoods work...they gave up and put original back on...seems like they had a lot of other fitment issues though
08-22-2018, 03:44 AM | #32 |
Re: Smooth Hood
For $200 I would try it, but shipping would be more than $200 to Nova Scotia LOL
08-22-2018, 07:28 AM | #33 |
Re: Smooth Hood
I welded mine,I did put a little filler strip down to keep bondo to a minimum,I have seen so many trucks with the bondo cracked all along the welded seam,truck is dusty but you get the picture.I think if I did it again,I would tack weld then glue a filler strip in before bondo.
08-22-2018, 11:54 AM | #34 |
Re: Smooth Hood
Regarding welding the seam, each hood half has a pretty large radius.whiere the flanges are formed. Do you fill the entire valley of the seam That would take lots of wire. I was thinking of using a piece of 3/16 diawire and let it form a peak after I skim ir. The rod would be tacked a bit at a time as suggested.
Any thoughts |
