Old 11-21-2020, 12:38 AM   #1
Asshat
Asshat's Avatar
Crate motor for a 63 C20?
Considering what the lowest cost option would be for a "complete" crate motor. Not looking for a huge motor or lots of HP, just a 350 or something like that. I'm ok with a carb, don't really want to mess with a computer and all that extra crap.
If I do get one, I would put a T5 behind it, or some other manual, over-drive trans.
Are there pretty good deals out there? Probably less expensive to buy a complete motor, than rebuild one, right?
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 11-21-2020, 12:48 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Crate motor for a 63 C20?
A new one is now 2800.00
https://www.ebay.com/itm/NEW-OEM-GM-...AAAOSwbaxckkQP
Otherwise you can get the 350 ZZ short block and put your choice of heads on it and cam
https://www.jegs.com/p/Chevrolet-Per...49884/10002/-1
Might be cheaper to buy a "core" off craigslist and use that for a reman motor.
Rebuild yours if you have the time
When I get to do mine, I will get a new block (1pc seal) and rebuild the engine to what I want
Old 04-02-2021, 07:40 PM   #3
Asshat
Asshat's Avatar
Not sure about some of these EFlay deals. Probably better to go with a reputable source like Blueprint, right? Summit Racing, Speedway Motors?
292, 4-speed
Old 04-02-2021, 07:58 PM   #4
Bigdav160
Bigdav160's Avatar
Blueprint is more reliable than a General Motors product sold through a GM dealer??
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-02-2021, 08:05 PM   #5
Asshat
Asshat's Avatar
Is that a question?
292, 4-speed
Old 04-03-2021, 11:52 AM   #6
gmc684x4
Summit can have decent prices on motors I got my gm l31 engine from them
Ebay i would not buy an engine from no real recourse for knock off parts inside engine
gmc684x4 is offline   Reply With Quote
Old 04-03-2021, 12:02 PM   #7
Asshat
Asshat's Avatar
Can you run a carb on an LS motor?
292, 4-speed
Old 04-03-2021, 12:05 PM   #8
geezer#99
geezer#99's Avatar
Of course you can.
Old 04-03-2021, 12:08 PM   #9
Asshat
Asshat's Avatar
Originally Posted by geezer#99 View Post
Of course you can.
That sounds like a good option. Should be simpler and less expensive than the wiring harness and computer. I could probably find an LS motor for about 500-600, right?
292, 4-speed
Old 04-03-2021, 12:32 PM   #10
geezer#99
geezer#99's Avatar
Don’t know cost. It would vary depending on popularity and availability.
Old 04-03-2021, 03:06 PM   #11
Dead Parrot
I went with a something like this: https://www.jegs.com/i/JEGS/059/7353/10002/-1 purchased new from a local Chevy dealer years ago. Went with an Eddy performer intake + carb and headers. Still going good many years and 100+K miles later.
For your 63, a set of ram's horn manifolds would be a nice match and probably less trouble then headers.
Dead Parrot is offline   Reply With Quote
Old 04-03-2021, 05:01 PM   #12
LS short box
Go to car-part.com and you can search for LS based engines. A T5 wouldn't be my first choice because it's a pretty light duty trans unless you buy the upgraded "World Class" or buy a used T5 and have it rebuilt with heavy duty parts. If you have the cash a TKO500/600 would be a better choice.
LS short box is offline   Reply With Quote
Old 04-03-2021, 06:56 PM   #13
Asshat
Asshat's Avatar
What about a V6, like from an S10? Are these worthwhile?maybe a GMC 305 V6?
292, 4-speed
Old 04-03-2021, 10:27 PM   #14
Greasey Harley
Greasey Harley's Avatar
Why not just have a reputable machine shop build you an engine?
You can specify parts: pistons, rings, gaskets, heads, cam, bearings, etc.
You can also spec compression ratio, quench, deck height, etc.
You can have it made any way you like, and you'll know exactly what you have.
Usually cheaper than a "crate motor" and most reputable engine shops will warranty the engine if they build it. It also supports your local economy.
Just a thought
-Russ
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 04-03-2021, 11:17 PM   #15
Asshat
Asshat's Avatar
Just a thought
-Russ
Good point. Gotta find a shop someplace around here.
Then again, I wouldn’t know what to spec, not sure what some of those things you mentioned are.
292, 4-speed
Old 04-04-2021, 12:50 AM   #16
Asshat
Asshat's Avatar
Are there RV cams available for the GMC V6 305E motor? I haven’t seen any.
292, 4-speed
Old 04-04-2021, 10:23 PM   #17
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The 305 V6's are cool as heck, but are antiquated dinosaurs. Not much in the performance upgrades for them anymore without shelling out lots of money. The late model V-6's in the S-10's are garbage. I've rebuilt and worked on more than enough over the years.
A basic 350 with 300 hp will be more than you need. EZPZ to build or have built for you. LS swaps can be done... but if you're going that route you might as well upgrade to EFI too. Lots of money to keep am LS with a carb on it, when you can just do that with a 350 that will basically fall in to your engine bay.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
