08-06-2019, 08:41 AM | #1 |
Roller Rockers
I recently purchased a set of world product Sportsman 2 heads in a bag of roller rockers we're throwing in with the deal no looking at the roller rockers they are earson brand there is a 1.6 on some of them and a 1.5 on some of them. My question is why are there two different racial numbers or are the 1.6 for the intake and the 1.5 for the exhaust or vice versa confused please help any info would be much appreciated
08-06-2019, 08:50 AM | #2 |
Re: Roller Rockers
Did you pay anything for the rockers ?
08-06-2019, 03:09 PM | #3 |
Re: Roller Rockers
It's a tuning deal. All depends on the cam. THe 1.6 gives more lift and duration than the 1.5's.
You can put them either way, all intake 1.6's or opposite. If you intend to use those rockers, you need to check them close (doesn't matter that they are Erson, check ANY used rocker...). Make sure the roller tips move freely, and have no play in them, no flat spots. Make sure the pivot is free, spins free. |
08-06-2019, 03:12 PM | #4 |
Moderator
Re: Roller Rockers
Need to know the specs on the cam, but if you're going to run splits, 1.6 on the intake, usually. You also need to look and see if the heads have guide plates. No guide plates: you need self-aligning rockers.
08-08-2019, 05:10 AM | #5 |
Re: Roller Rockers
Jayoldschool, i am not sure of cam specs and the guy i got motor from didnt seem to remember.Yes heads have guide plates. What would you suggest running the 1.6 and 1.5' for intake an ex.?
Heads have 2.02,1.94 valves.64cc,200cambers angle plug. 68Gold/white,i did check them over real good no apparent issues that i see. YoungPup1977, rockers came with head.paid $300 and a 12 pk . Thanks for everybodies input, I have never got bad advice from this forum!!!!!! |
08-08-2019, 06:40 AM | #6 |
Re: Roller Rockers
I always figured the exhaust was the weaker side and more apt to appreciate the 1.6 rockers.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
08-08-2019, 11:26 AM | #7 |
Re: Roller Rockers
I would put the 1.6 on the intake side. You want to get more fuel into the motor for more power.
08-08-2019, 12:00 PM | #8 |
Re: Roller Rockers
I wouldn’t decide on either set until I had the heads checked for cracks!
When you get stuff cheap with freebies thrown in, there’s always a catch! |
08-08-2019, 01:45 PM | #9 | |
Re: Roller Rockers
Doesn't do any good to put more in if you can't get it back out. Let the exhaust breathe.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
08-08-2019, 06:13 PM | #10 |
Re: Roller Rockers
08-09-2019, 09:56 AM | #11 | |
Re: Roller Rockers
08-09-2019, 04:50 PM | #12 |
Re: Roller Rockers
I ran a 377 small block that had 1.6 ratio rockers on the 4 outer intake valves. Theory was that the outers had longer intake runners so the 1.6 helped push more air/fuel to the outers. Not sure if it made a difference but it was a strong running motor.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
