Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 10-18-2020, 01:35 PM   #1
Asshat
Asshat's Avatar
Valve spring compressor - Lisle 44300
Anyone know how this tool goes together? Cannot figure this out.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 10-18-2020, 01:54 PM   #2
Asshat
Asshat's Avatar
Re: Valve spring compressor - Lisle 44300
I just don’t get how the bolt can go through the handle and link assembly. If it does the thing won’t pivot to compress the spring.
292, 4-speed
Old 10-18-2020, 02:00 PM   #3
Asshat
Asshat's Avatar
Well, I thought I had it. Just doesn’t seem like I can get any leverage with this thing.
Am I that slow? Can’t even figure out a stupid lever.
Got this other image from the web, but it shows it inverted. How the heck can you install valve stem seals with the head inverted? Geez.
292, 4-speed
Old 10-18-2020, 03:27 PM   #4
weq92f
Here's a picture of the thing assembled as described in the docco you posted. Once you have this, just tighten it to your head then put pressure on the handle to compress the spring?
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 10-18-2020, 03:54 PM   #5
Asshat
Asshat's Avatar
-klb
Thanks. That works.
292, 4-speed
Old 10-21-2020, 07:14 AM   #6
Stormin08
Stormin08's Avatar
they actually work rather well. key is to not drive the threaded rod out too far, just enough that the lever arm can cycle and compress the spring just enough to remove the keepers
Stormin08 is offline   Reply With Quote
