Old 11-25-2014, 01:09 AM   #26
zipper
Re: Who is running manual valves?
Originally Posted by Tx Firefighter View Post
I'm running a Little Larrys valve block. I chose it over the DLOE route simply due to sanitary installation and the fact they are quick and easy to rebuild with generic o rings if ever needed.
The sanitary part comes in where you just have one inlet feed from your tanks to all four valves. And the combined single exhaust port is nice too since it was easy for me to run my dump line down and under the truck for quietness and cleanliness.
Were did you get your fittings from?
zipper is offline   Reply With Quote
Old 11-25-2014, 11:43 AM   #27
chevy_mike
Never Ending Projects
chevy_mike's Avatar
You can get them directly at http://www.littlelarrys.net/
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-25-2014, 12:21 PM   #28
PAPABEAR
I think zipper is looking for the ptc fittings that TX used behind the valve block.
PAPABEAR is offline   Reply With Quote
Old 11-25-2014, 03:06 PM   #29
hanly2
Newfisher do you have any videos of it in action? How loud was the dump inside the truck since you cant run a exhaust with those valves.
hanly2 is offline   Reply With Quote
Old 11-25-2014, 03:15 PM   #30
NEWFISHER
NEWFISHER's Avatar
I don't have a video of the truck,it was sold earlier this year. I am still in contact with the owner. let me see if he can take one?
4-5 seconds down and 4-5 up. The exhaust noise out the backside wasn't obnoxious. It shoots under the dash and where you sit, you are not bothered by it.
I have a V2 system now and If I do another manual system I would do the same set up from Borris. The Larry's paddles look good, but a little large to find a spot for. I didn't want to cut a hole in the dash of the 46 nor did I want the gauge /paddle pod to hang below it so I went with the V2. Everything is displayed on the screen and can tuck it away if I want. It was only a few hundred bux more than a manual set up if you search.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 11-27-2014, 11:24 AM   #31
hanly2
I just came up with another question. If I decide to run the 1/4 line with the slower speeds is it going to be unecessary to have 2 compressors? I was going to buy 2 of the viar 444c's and a 5 gallon tank.
Old 11-27-2014, 02:32 PM   #32
SCOTI
SCOTI's Avatar
I would still do 2 compressors. The amount of air to refill the bags after deflation will have a single compressor running much harder.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol....
Old 11-27-2014, 03:29 PM   #33
PAPABEAR
Now I have a question when using manual valves running two compressors one tank how far away can the compressors be mounted from the tank? Say tank on one side of frame and compressors on the other. Would that effect speed?
Old 11-27-2014, 04:34 PM   #34
SCOTI
SCOTI's Avatar
Negligible most likely.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-27-2014, 04:55 PM   #35
NEWFISHER
NEWFISHER's Avatar
2 comps and a 5g would be perfect for 1/4 line. Im running a single comp now and if you dump and refill twice, the comp runs a while. With 2 that cycle would be much quicker.
GOD BLESS AMERICA!
Old 11-29-2014, 08:51 PM   #36
hanly2
Newfisher are you running 1, 1/4 line from the tank to the valves and then splitting it somehow?
Old 11-30-2014, 11:21 PM   #37
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Sorry I didn't see your question earlier.
I bought them, along with a ton of other stuff from tho robros.com
I had to put that space in his website name due to board politics. Apparently there is bad blood between them and the admin here so when you type his website on here it gets censored.
I know nothing about the feud that caused it, but he (Jason Thorbec ke) did me very right on all of my orders. I'm a very loyal customer to them.
Kevin -
My Instagram
Tx Firefighter is offline   Reply With Quote
Old 11-30-2014, 11:31 PM   #38
hanly2
are they the ptc fittings? I can't find the ones borris uses in those panels anywhere
Old 11-30-2014, 11:33 PM   #39
Tx Firefighter
Yes, they're push to connect.
Quality seems good. I used them throughout the system and I can set pressures and the entire system holds exact pressure for weeks without leaking off.
Kevin -
My Instagram
Old 10-25-2017, 11:18 AM   #40
Corte's Speed Shop
Any updates on those of you running the FourPlay Valve setup? Thinking about ordering and haven't been able to find much in the way of reviews.
Corte's Speed Shop is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
