Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 10-19-2017, 08:19 PM   #1
6796Chev
Wiring bug please help!!!!
To start things out, I drive a 96 2dr Tahoe 5.7 L that has just recently stared having issues. first off I had an issue with what I though was my alternator/battery..both were replaced with Optima yellow top/100A alt. Secondly there was a coolant leak issue that ended up needing intake manifold replacements. all of which have been done the past couple of days and it still wont start Not that these issues are related. I am trying to figure out why my brand new battery is already dead? Any ideas where a constant battery drain would come from?? BTW it is ACCUAIR E-Level equipped. Any suggestions/thoughts/anything helps.
6796Chev is offline   Reply With Quote
Old 10-19-2017, 09:24 PM   #2
franken
Re: Wiring bug please help!!!!
Disconnect the negative post. Get a battery charger and start charging. It will take time as in many hours to charge if its really dead. A charged battery is 12.6V DC. Get a voltmeter and measure the voltage on the battery. Turn on the lights for a few minutes before measuring. What's the voltage?
If it starts, what's the voltage on the battery w/ the engine running?
If you suspect the battery is being drained, keep the negative disconnected when not in use.
Check w/ a test light between the negative post and cable.
Or that's what I'd do...
Old 10-19-2017, 09:47 PM   #3
6796Chev
Ok I will give it a try thanks franken
Old 10-21-2017, 07:32 AM   #4
speedygonzales
speedygonzales's Avatar
Update
So where we at now?
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 10-21-2017, 03:41 PM   #5
6796Chev
still stuck... the battery is fine but when I go to turn the motor over the starter seems to not have enough torque to start. other than replacing the starter is there anything else you guys can think of? can it be a timing issue?
Old 10-22-2017, 07:59 AM   #6
speedygonzales
Let's clarify
OK so when you said it won't "start" you actually meant it won't "CRANK"?
Big difference between won't start but cranks and won't crank.
What is the voltage at the starter on the large wire connected to the battery when someone it is being cranked?
If you are getting at least 11 volts at the starter when it is cranked and the starter is still not cranking correctly, either the starter is bad or you have a couple of cylinders hydro locked.
And no the timing can't be off in a Vortec unless you reinstalled the distributor wrong.
Pride and joy
Old 10-23-2017, 01:53 AM   #7
6796Chev
You're right, sorry my wording was a little confusing. The motor is cranking over but not starting. Replaced the starter today and messed with the distributor and we think we have it back on an alignment mark that validates our mark of the position from when it was removed.
The voltage on the battery looks to be good, don't recall the exact number, and the drain has been cured.
When engaging the starter the motor rotates slowly and then stops. A second attempt yields a faster rotation and the sound of the engine trying to fire. We've gone through this process multiple times, on a couple occasions on the second and/or third try it does sound like it wants to run but stalls. After the second or third attempt there's a clunking sound and it sounds like a large rush of air back through the throttle body. So the hydro-lock sounds like it might be the issue behind this.
Old 10-23-2017, 06:51 AM   #8
95 S_Trucker
95 S_Trucker's Avatar
My guess is the distributor wasn't put back in the same place during the intake manifold gasket replacement.
Has the engine run since the intake manifold gaskets were changed?
Bring the engine to TDC compression stroke. Install the distributor with the rotor pointing at the little triangle with the 8 on it. You may have to turn the oil pump drive with a long screwdriver to get the distributor to seat properly.
That will get you running. After that, you should get someone with a scanner, and adjust the cam/crank signal to 0+/-2 degrees.
-99 K2500 LS CCSB 7.4
-96 C3500 HD 7.4 NV4500 Rollback
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
-62 Lincoln Sedan 430 Auto
-61 Lincoln Convertable, 430 Auto
85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is offline   Reply With Quote
Old 10-24-2017, 01:04 AM   #9
6796Chev
Thanks 95 S_Trucker this helped a lot. I spent the time to change the spark plugs and wires while we were at it. Well see tomorrow if this solved the issue. Fingers crossed
Old 10-24-2017, 07:17 PM   #10
6796Chev
when you say bring to TDC, I am assuming that's starting from the 1st cylinder?
Old 10-24-2017, 07:51 PM   #11
95 S_Trucker
Yes, tdc for cyl 1 compression stroke.
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
Old 10-26-2017, 01:36 AM   #12
6796Chev
So here where we stand. Got everything back together and running but its still running a little rough. Seems like there is a misfire. From what I understand camshaft timing has to be set at +-2 with a scan tool? any recommendations on good/affordable scanners? or can this be done without a scanner?
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
