Old 11-06-2017, 10:47 PM   #1
JimmyS10
Help with V6 Engine Suffix Codes
Talk about frustrating! Anyone called GM recently? After an hour and a half on the phone with 6 departments I'm no further in my quest than I was earlier. Hopefully someone on this board can help.
I am in the process of building a hot rod 28 roadster. I've decided to use a GM V6 powerplant for a number of reasons. Anyway, I was able to pick up a V6 pretty cheaply. Before putting in the roadster I want to rebuild it. In order to rebuild it I have to identify it so I get the correct parts. Seems simple so far, right? Well, everyone wants the year, make, model and VIN of the donor vehicle. I tried to explain to GM that is what I am calling them for. If I had that, I wouldn't need to be calling. Anyway, the VIN would only be valid IF the engine was the original for that vehicle. So, I'm looking for info from some of you more knowledgeable folks. Here's what I have and am trying to identify:
GM V6 4.3 L 4bbl carb
Engine ID = T1121UTC
Block Cast = 10105867
I know T = Tonawanda Buffalo, NY
1121 = 11/21
It appears to be an 87-91 based on the casting number.
Can anyone help identifying this engine further? Thanks in advance.
JimmyS10 is offline   Reply With Quote
Old 11-07-2017, 12:11 AM   #2
Captainfab
60-66 Nut
Re: Help with V6 Engine Suffix Codes
I don't know of any sources for 4.3 V6 suffix codes. If you get the casting date off of the block that should be all you need to tell you the date of the engine and then you will know what year range of parts to order. Does this engine have a balance shaft?
Old 11-07-2017, 12:56 AM   #3
geezer#99
geezer#99's Avatar
Here's a little known source for your suffix code.
Appears to be a 1990 motor in a full size type truck.
http://www.lmctruck.com/icatalog/cd/full.aspx?Page=9
Old 11-07-2017, 08:45 AM   #4
b454rat
Not with a 4barrell. That would be 84-86-ish.
Old 11-07-2017, 08:45 AM   #5
Keith Seymore
Keith Seymore's Avatar
Nicely done, geezer.
Jimmy - another quick sort would be carbureted vs fuel injected. Is your motor TBI?
K
Chevrolet Flint Assembly
1979-1986
1986 - Present
Old 11-07-2017, 08:47 AM   #6
b454rat
Should have stated, what does the casting date day on the intake? I’ve never heard of a carbed motor in 1990. Any competent machine shop should know how to rebuild it.
Old 11-07-2017, 03:48 PM   #7
95 S_Trucker
95 S_Trucker's Avatar
All of the 4.3 v6 engines made between 87 and 91(casting number) were fuel injected, so someone swapped the carb on.
-99 K2500 LS CCSB 7.4
-11 GMC 2500HD SLE CCSB 6.0
-96 C3500 HD 7.4 NV4500 Rollback
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
-62 Lincoln Sedan 430 Auto
-61 Lincoln Convertable 430 Auto
85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is offline   Reply With Quote
Old 11-07-2017, 05:57 PM   #8
Bigdav160
Bigdav160's Avatar
I thought the only 4.3L with a carb were in Astro vans and marine powerplants.
Of course the old 229 was carbed.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-07-2017, 08:24 PM   #9
95 S_Trucker
85-86 in the c/k trucks were carbureted.
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
Old 11-07-2017, 09:06 PM   #10
Bigdav160
Bigdav160's Avatar
I was working at Oldsmobile at that time. We didn't see many trucks.
But I can't remember ever seeing V6's in square body trucks. Straight 6, yes
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 11-10-2017, 01:28 AM   #11
Greenlee
They did exist. I remember a neighbor who bought a brand new 85 2WD short bed that had a V6.
Greenlee is offline   Reply With Quote
Old 11-10-2017, 01:57 AM   #12
JimmyS10
Thanks Geezer. Great find. That said, I found another number cast on the passenger side of the motor beneath 15 layers of paint and crud. That number is K169. That, I interpret to be October 16, 1989. So late 1989 and stamped 1990. TBI most likely removed and carb installed would be my guess. Is my thinking correct? Thanks again everyone...Jimmy
Old 11-10-2017, 09:23 AM   #13
Bigdav160
Bigdav160's Avatar
Pretty sure marine versions were carbed to the end.
But yes, throttle body injection was used in passenger vehicles 87 and newer
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Copyright ©2000 - 2018, vBulletin Solutions Inc.
