Old 04-14-2014, 08:45 PM   #1
Hudsonaj36
Hudsonaj36's Avatar
How do you remove transmission crossmember?
So I dropped my transmission so can put in a better torque converter. All I could do with cross member was unbolt it and beat it back towards the rear. Made getting the tranny out a real pain. Would like to make the install easier by removing it he crossmember.
Does the crossmember come out some how without cutting it, would like to reuse it.
Seems like it's stuck between the frame rails.
1968 c1500 2wd th350
Hudsonaj36 is offline   Reply With Quote
Old 04-14-2014, 08:50 PM   #2
cableguy0
Re: How do you remove transmission crossmember?
There is one spot on the frame where you can knock one side of the crossmember sideways and eventually it will come out. Also you can remove the rivets that hold the two extensions that go to the top of the frame and replace them with bolts. That way you can just flip the crossmeber upright and turn it sideways easily. In all reality 8 bolts is complete overkill to hold a transmission crossmember. I have removed the upper pieces completely in the past. Every aftermarket crossmember around only uses 4 bolts.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-14-2014, 09:13 PM   #3
crazy longhorn
Fabricate till you "puke"
BFH...a pretty big hammer! I do agree with Cable, knock the top wings off, & do the twist Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-14-2014, 10:29 PM   #4
Hudsonaj36
Hudsonaj36's Avatar
Copy that, I'm going to knock the wings off it. Thanks
Old 10-20-2017, 07:02 PM   #5
Richard2112
Wish I had read this before the bloody knuckle struggle to remove that crossmember. I can see where it it is (by far) easier to knock the wings off. Doing that tomorrow.
Richard2112 is offline   Reply With Quote
Old 10-20-2017, 08:54 PM   #6
garyd1961
I put a new motor and trans in my 70 C10 and didn't even unbolt the crossmember. I just jacked the tailshaft up and slid it over the crossmember.
garyd1961 is offline   Reply With Quote
Old 10-20-2017, 09:28 PM   #7
hewittca
hewittca's Avatar
Same experience here. I have a nice little scar across my knuckle now reminding me of the fight put up by my crossmember. After taking the upper bracket pieces off, the crossmember came right out...
Build: Green Gus
Instagram: @dr.hewitt
Concept Photos: Master Thread
hewittca is offline   Reply With Quote
Old 10-21-2017, 12:50 AM   #8
Captainfab
60-66 Nut
Yes you first need to remove the rivets holding the 'wings' to the main crossmember. Then it comes out easy and goes back in easy.
Old 10-21-2017, 09:30 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Can someone explain how you "knock the wings off"?
Do you cut them off or grind/cut the rivets off to remove it. Unless a person has an oxy/acetylene torch kit or a good compressor and air hammer and chisel kit it's a pain to remove those rivets.
I removed the crossmember on my original six cylinder 69 Chevy like Longhorn mentioned -with a big sledge hammer. Chiseled the rivets of then after I got it out I ground a small section of the corner edges on opposite ends of the crossmember to make it easier to bang it back in.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-21-2017, 11:52 AM   #10
Coley
Coley's Avatar
..does anyone have any pics of this before or after?...either the cross member, or everything place or out?
I might end up doing this someday if I swap out my TH350 for a 700R and I assume I will be having to move/remove this thing to mount up the 700R.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 10-22-2017, 09:23 PM   #11
Richard2112
There's a few different ways to accomplish this but I've found that "knocking the wings off" is a great idea.
I have cut the heads of the drive rivets off with a sawzall and a metal cutting blade, then trilled out the body of the rivets, then punched to re3maining fragments out. Some people use an air chisel and that works great if you have one.
In any case, a hammer and pry bars still come in handy. Still, it easier done with the trans removed. If the trans is still in, your only option may be to "knock the wings off' but I would recommend it either way
Old 10-26-2017, 06:48 PM   #12
'68 C10
Ive removed two now...
'67 Stepside - had to unbolt cab mounts and lift cab up to remove top bolts. Successfully hammered it out at an angle.
'72 LWB - able to remove top bolts w/o lifting cab but hammering out crossmember was a no-go. A grinder made it easier to remove in two pieces lol.
'68 C10 is offline   Reply With Quote
Old 11-03-2017, 10:57 PM   #13
YoungPup1977
YoungPup1977's Avatar
Over the years I have removed hundreds of these by using my blue wrench....cut the top frame rail bolts and install shorter bolts up from the bottom side of the upper frame rail.....easy stuff....got to love the words "knock off the wings" LOL!!!!!!!! just cut the rivets and replace with bolts if you like, I normally don't but there are times the cross member will not go back in like you want it to, so cutting the rivets helps the install...but "KNOCK THE WINGS" off....now thats doing something !!!!!
YoungPup1977 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
