Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 10-18-2017, 10:53 PM   #1
JAG66
Cut top or bottom of coil spring?
Lowering my 1996 shortbed. Plan to cut about 1/2 coil off. What is best, cut bottom of spring or top of spring?
Is there an indented "stop" in the upper spring pocket that would need lining up with the coil end?
I know there is an indented stop in the lower control arm. Is this where I should line up the coil end after cutting and re-installing?
JAG66 is offline   Reply With Quote
Old 10-23-2017, 10:04 PM   #2
JAG66
Re: Cut top or bottom of coil spring?
Who are the experienced here?? I have searched the forums.
Old 10-25-2017, 02:45 PM   #3
memphismatt
memphismatt's Avatar
I am interested to know also as I have considered this myself.
'68 C 10 short step
'92 C1500 RCSB
'92 C3500 ECDRW
'96 C1500 ECSB
memphismatt is offline   Reply With Quote
Old 10-25-2017, 08:59 PM   #4
Tom
driving is in my blood
Tom's Avatar
Pretty sure its top as the bottem is more spring rate which you need. As to the rest, no idea. I just spend the $100 for proper springs.
-06 CBR600F4i: 110mph in 2nd at 14,000rpm= happiness.
-02 Suburban 4x4: stock
Old 11-01-2017, 12:15 PM   #5
Never enough
Never enough's Avatar
I don't remember if the top is indented also, but if it is, you need to cut 1 coil so both ends line up in the pockets, called "clocking". 1/2 coil is going to cause issues, squeaking and possibly the spring sliding into and destroying the shock.
Also, if the top of the spring is "sqaured off" meaning it lies flat on the frame, I would consider replacing with correct lowering springs as after it's cut, the sharp end of the spring will rest unevenly on the frame pad and can cause the same issues as not taking a full cut on a clocked spring.
1969 Chev C10
1989 Chev R3500
Never enough is offline   Reply With Quote
Old 11-15-2017, 10:49 PM   #6
JAG66
UPDATE:
Removed my coils
There is NOT an indent at the top of the spring pocket.
There IS an indent in the lower A-arm where the coil is "clocked"
The top of the coil is squared off, so would not cut here.
The bottom is tangential, so this is where to cut.
Old 11-16-2017, 02:04 AM   #7
mongocanfly
I've always cut the bottom..
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
