Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 10-21-2017, 05:19 PM   #1
codejitsu
Couple of questions about my 94 k2500 oil pressure and trim ?s
Ok so to start the truck is a 94 k2500 with a tbi350 with 120,000 miles. Oil pressure when idiling warm gets very low, but never goes into red and check engine light has never come on. Oil pressure runs around 40 when driving. Engine feels good despite the pressure reading. Does anyone know what could cause this? Bad oil pump? A bad sensor? Also the truck has god awful chrome "trim" along the lower rocker area. How can I remove this without damaging the paint underneath?
'72 Blazer DD 33's
'78 F-250 w/ 1 tons and 37s
'41 olds 98 on bags
2011 vw jetta (wifes)
codejitsu is offline   Reply With Quote
Old 10-21-2017, 05:42 PM   #2
Re: Couple of questions about my 94 k2500 oil pressure and trim ?s
What kind of oil are you running? I found that when I used some vavloine oil in mine, The oil was so thin and runny, especially after time, my oil pressure was real low at idle and fairly normal while running. I switched back to the normal Castrol Hi mileage I normally use and the issue went away.
I have never seen anyone get that silver trim off without issues. You can try and heat guy to get it loose and some WD40 to soften the glue. You may stilll have issues with it pulling the paint. For sure at this age it will be a very different shade that what has seen the sun all these years.
1981 GMC High Sierra SWB Stepside
"Whitey" 2002 Chevy Silverado 1500 SWB W/T
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 10-21-2017, 08:33 PM   #3
codejitsu
Thanks for the reply. I'm running a Castrol full synthetic 10w 30. I'll try switching to the high mileage oil and see what happens. I may just leave the trim on. That doesn't sound very fun.
'72 Blazer DD 33's
'41 olds 98 on bags
Old 10-23-2017, 07:49 AM   #4
74CustomK20
74CustomK20's Avatar
When I pulled my trim off it left the glue behind. I wasn't worried about it took my wire wheel to it and wound up rhino lining the bottom.. good luck!
Nathan "Big Nate" Wood
Carp. Local 224. Buy made in the USA!
74 C30 350 manual 4 speed
74CustomK20 is offline   Reply With Quote
Old 10-23-2017, 12:50 PM   #5
Mr_Rich
Mr_Rich's Avatar
On the trim in the lower rocker area you can use a tool the body shops use. It is a glue/ adhesive "eraser" that you insert in a drill chuck. It's kind of like a rubber grinding wheel. I removed the molding on my K2500 and then used this tool to remove the adhesive without any damage at all to the paint. I had to charge my drill about 3X but finished the job. Buy this wheel at auto paint shops. It's worth it!
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M.
1997 K2500 Chev. EC 7.4L/ 4L80E
Mr_Rich is offline   Reply With Quote
Old 10-23-2017, 05:26 PM   #6
codejitsu
I'm going to buy one today when I get off work. Thanks for the advice guys. I'll give it a shot this weekend.
'72 Blazer DD 33's
'41 olds 98 on bags
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
