Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 Chevy & GMC Pickups Message Board
Old 11-01-2017, 12:16 AM   #1
Stephen717
Active Member
Stephen717's Avatar
Fuel prime? Problems help.
Hi, I am new to this section but not the site, I have a 1997 GMC k2500 with a 7.4l V8. Since owning it I have replaced the tires twice, front brakes calipers rotors and lines up front (haven't done the back ones yet), spark plugs wires cap and button, ignition coil, ignition control modulator, fuel pump, fuel pump relay, valve cover gaskets, hard line going to one of the rear brakes, and headlights. We have since noticed that at idle in park or neutral it has a slight miss and since we replaced the coil, control modulator, and fuel pump relay, every once in a while when I start it it shuts off after a few seconds like it's losing prime, but when I start it back up it runs fine other than the slight miss which it's had since we got it. Can anyone help my figure out what's going on here, if so that would be great.
Thanks,
Stephen
Stephen717 is offline   Reply With Quote
Old 11-01-2017, 02:53 AM   #2
Stephen717
Active Member
Stephen717's Avatar
Re: Fuel prime? Problems help.
It has 194,??? Miles on it, almost 3 where I am and forgot to check when I got home this evening. I don't know if it's a clogged fuel filter causing this issue or if it's something else though. Couldn't find any information online about it so thought someone from the forums could help me, any info would be great.
Thanks,
Stephen
Old 11-01-2017, 12:40 PM   #3
74CustomK20
74CustomK20's Avatar
I know it's a ranger, but my 96 had a missed right at 800 rpm, nowhere else in it's rpm range. Once the tranny went and it got too rusty to fix, I tore it apart outta curiosity to see what it was and it had a burnt valve causing that. But a new fuel pump fixed my loosing prime issue like you have.
Nathan "Woody" Wood
Support America, buy MADE IN THE U.S.A.!
1977 K10 to K30 - Parted out to bare frame, rebuilding now.
98 K2500 6.5 Turtle Diesel.
74CustomK20 is offline   Reply With Quote
Old 11-01-2017, 01:04 PM   #4
sntrym95
sntrym95's Avatar
I would start with the fuel filter. Cheap and easy part to replace, probably needs it anyway.
Mike
Toy list:
1995 C1500 Ext. Cab 5.7
1995 GMC Yukon 4dr 2wd 5.7 Vortec conversion, AAM TracRite, Lincoln Mark VIII fan conversion
1979 Mako 23 CC
sntrym95 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
