Old 11-04-2017, 09:03 PM   #1
TylerHuff
TylerHuff's Avatar
Clutch won't release
I have a new slave cylinder and had a shop bleed it. I have replaced the clutch pressure plate, pilot bushing and throw out bearing. Clutch would not release and I was told the new pressure plate was bad so I got a new one and replaced it. Now it still won't release.
1987 Gmc sierra
1962 Apache 10
TylerHuff is offline   Reply With Quote
Old 11-04-2017, 11:35 PM   #2
YoungPup1977
YoungPup1977's Avatar
Re: Clutch won't release
YoungPup1977 is offline   Reply With Quote
Old 11-04-2017, 11:35 PM   #3
kwmech
Disc in backwards?
Old 11-04-2017, 11:59 PM   #4
TylerHuff
TylerHuff's Avatar
Made sure it was in correct the second time and it was. Also the hydraulics have been bled at a shop after I couldn't get it to release the first time.
1987 Gmc sierra
1962 Apache 10
Old 11-05-2017, 02:47 AM   #5
mongocanfly
do you have the slave properly shimmed?
Old 11-05-2017, 06:37 AM   #6
D13
D13's Avatar
Wrong throw out bearing? There are a short and a long and they don't interchange.
1987 C10 6.2 oil burner
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
77 1/2 ton 250, 3OTT, and hokey aftermarket AC
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 11-05-2017, 09:12 AM   #7
TylerHuff
TylerHuff's Avatar
There were no shims on the old slave and if I put them on the new one I would have less travel. The throw out bearing Is exactly the same as the one that came out. I compared them side to side.
1987 Gmc sierra
1962 Apache 10
Old 11-05-2017, 09:39 AM   #8
homemade87
A improper or improperly installed pilot bearing (bushing) will do this . If the bearing is not seated all the way ( or to long ) the input shaft will bind against it and keep it turning . Clutch will have no affect .
I would first get someone to work the clutch pedal while you are looking at the plate to see if it releasing . You should have at least .010 on both sides of the clutch disc to release proper . If it is releasing I would look into the pilot bearing . Could also be the hole in the bushing is a little to small and keeping the shaft turning .
homemade87 is offline   Reply With Quote
Old 11-05-2017, 10:02 AM   #9
geezer#99
geezer#99's Avatar
They might be the same but are the pressure plate fingers the same?
Old 11-05-2017, 03:26 PM   #10
mongocanfly
tyler..I just helped a buddy swap from auto to stick....and the instructions for the slave specifically called for it to be shimmed...remember...it doesn't move much....we installed bellhousing on block and measured to clutch fingers and then turn around and measure the other way to the trans....the difference is how much it needs shimmed...shimming does not change the amount of travel....it simply moves the slave into the proper operating position. ...if its not in the right spot all your doing is pushing air...have you looked to see if its contacting the clutch fingers...you could mark it with a sharpy or dikum to check if you can't get to where you can see...
also as homemade says...could be a binding pilot ...
Old 11-06-2017, 12:06 AM   #11
Captainfab
60-66 Nut
Was this with a hydraulic release bearing? The OP's truck has an external slave that pushes on a fork. He has 2 different threads about the issue, so it is difficult to know the details of what he is working with.
Old 11-06-2017, 01:33 AM   #12
mongocanfly
my bad...I guess I didn't understand what he was referring to...I thought he was talking about a hyd release throwout bearing..not the external one....guess I should have read it closer...
and yep Capn...that's what my buddy had...hyd throwout..
Old 11-06-2017, 10:27 PM   #13
TylerHuff
TylerHuff's Avatar
The slave is external and if it were to be shimmed it would be farther away from the clutch fork. I don't think the pilot bearing could be the problem, when I installed the tranny I didn't have any problems getting it lined up and it slid into place fairly easily. I did replace the master cylinder tonight and got a lot better feeling on the pedal but I may not have got all the air out of it.
1987 Gmc sierra
1962 Apache 10
Old 11-16-2017, 02:21 AM   #14
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Did you mike the throwout bearing or just eyeball it ? On some applications the difference is only 1/16 of a inch or less.Let us know the fix when you get it.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is online now   Reply With Quote
Old 11-17-2017, 10:50 PM   #15
TylerHuff
TylerHuff's Avatar
UPDATE. The issue has been resolved. I took it into a shop and they pulled the clutch and installed a new one but a different brand and it works perfectly fine. I purchased 2 brand new clutch kits from Napa and both of them were bad. Sachs clutch works great.
1987 Gmc sierra
1962 Apache 10
Old 11-17-2017, 11:16 PM   #16
mongocanfly
GREAT!!!!...glad you got it figured out
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 11-18-2017, 12:14 PM   #17
Husker
Husker's Avatar
sounds like an expensive clutch replacement.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 11-19-2017, 09:04 AM   #18
Marv D
Registered Truck Offender
Marv D's Avatar
This is unfortunately becoming all to familiar with many of the old tried and true parts chains,,CarQuest, NAPA, Advance... They are having to give up the quality US made items to compete with the crap PepBoys, Autozone Orielly's, RockAuto and evilbay motors.
If people won't spend the extra $ to buy American,, the old 'tried and true' has to put the cheap import parts on their shelf,, then they have an overpriced import POS just like everyone else.
I had a similar experience with a CarQuest TPS with 2 being bad,, first electronically defective and a second the internal return spring was broke,,,, Of course it took a weekend of diagnosis to figure out WTH was going on. Ended up I had to go buy a imported POS from Autozone on a Sunday afternoon and guess what,.. it WORKED flawlessly.
It's a sad statement to make but this same scenario is happening all too often.
Sorry to hijack the post Tyler but just has to share and say,,, I feel your pain buddy.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
