Old 05-16-2018, 08:05 PM   #1
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Question I Need Water Pump Torque Values?
I'm in need of the 6ea mount bolts and the idle pulley nuts on an all aluminum 5.3L block RPO LO8 2010 Colorado.
Tnkx.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 05-16-2018, 09:09 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: I Need Water Pump Torque Values?
For the water pump: First pass is 11 ft/lbs. Second pass is 22 ft/lbs.
The 3 bolts for the belt tensioner should be 37 ft/lbs.
-99 K2500 LS CCSB 7.4
-11 GMC 2500HD SLE CCSB 6.0
-96 C3500 HD 7.4 NV4500 Rollback
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
-62 Lincoln Sedan 430 Auto
-61 Lincoln Convertable 430 Auto
85 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=368864
78 Big10 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=383629
96 Project: http://67-72chevytrucks.com/vboard/s...d.php?t=614515
95 S_Trucker is offline   Reply With Quote
Old 05-17-2018, 02:07 AM   #3
truckdude239
truckdude239's Avatar
Are you looking for torque specs or are u looking to buy the bolts and nuts?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
2003 Honda Accord 109k( brothers car)
2002 Sububran 5.3 225k
2000 Tahoe 5.3l 369k
Old 05-17-2018, 08:22 AM   #4
95 S_Trucker
Title says torque values?
If you need the bolds, get them at the dealer, hardware store bolts look out of place.
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
Old 05-17-2018, 03:18 PM   #5
87 STEPPER
87 STEPPER's Avatar
Thumbs up Re: I Need Water Pump Torque Values?
Thanks 95 S Trucker that's what I was looking for.
In the aviation profession a fastener Torque is known as or referred to as a Value not a Spec.
Are the water pump mount bolts on the LS engines known for going bad?
I've had this truck 4 yr's and it's the original pump and this is the first thing that I've had to replace on it other than plugs n wires.
I don't know if the hardware is good or bad as I am still driving it I plan to do the water pump this weekend. It's leaking out the weep hole after only 267.000 miles.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 05-17-2018, 03:32 PM   #6
truckdude239
Ive never repalced water pump bolts on an ls and i've done abunch of them at work
David fuller
Old 05-17-2018, 03:43 PM   #7
95 S_Trucker
Youre first sentence says you are in need of 6 bolts and nuts for the idler. It was a little unclear on this side of the screen.
The bolts don't go bad.
-85 K10 5.7 700r4
-78 K10 5.7 4 Speed
-90 ZR1 5.7 6 Speed
Old 05-17-2018, 05:53 PM   #8
87 STEPPER
87 STEPPER's Avatar
Wink Re: I Need Water Pump Torque Values?
Yeah I can see how that looks like I'm looking for the hardware sorry for the confusion.
Thank you both for this info.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 05-17-2018, 07:53 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Just replaced the water pump on my LQ4 in my '06 Silverado. Reused the original bolts... no prob.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
