Old 11-08-2017, 10:40 AM   #1
firemaned52
1984 chevy cab/chassis
I just acquired a 1 ton C&C and want to lower it 5/7 like a lot of trucks pictured on this site. I was looking at the 14 bolt rearend and noticed that the spring perch is cast. Do I still use the same flip kits as a Dually pickup. Any recommendations about which company to use for the the parts. I bought this truck because it has zero rust. thanks for any help.
firemaned52 is offline   Reply With Quote
Old 11-08-2017, 01:28 PM   #2
daddyjeep
daddyjeep's Avatar
Re: 1984 chevy cab/chassis
I can't answer your question, but I can welcome you to the forum and say congrats on getting your truck.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 11-13-2017, 11:55 PM   #3
RoscoTom
What's the chassis?
My 84 1 ton C&C has a stack of leafs a dump truck would be proud of.
Wouldn't you have to throw all that away to lower it?
DRW or SRW?
Tom
RoscoTom is offline   Reply With Quote
Old 11-14-2017, 10:41 AM   #4
firemaned52
Its a DRW cab and chassis. Yes it has a bunch of leaves but leaving out the overloads. I think the rest of the rear is like a Dually, 14 bolt just a little shorter is all.
