Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Forums > Past Contest Winners > 2019 ToTM Archive
Closed Thread
Old 01-16-2019, 10:09 AM   #1
February 2019 ToTM
Since the name is being reborn, our first contest theme for the new year will be based around those vehicles that started the craze for GM. So, our theme for the February 2019 Truck of the Month (ToTM)
Flare-up!
If you need help, our theme is the inferno that set the GM utility vehicle market ablaze. In case you need help, our theme is the 2-door based SUVs, that started with the Blazer
Here are the criteria for this month’s contest.
  • Open to all years and models of Blazers, Jimmys. 2dr-Tahoes, and 2dr-Yukons.
  • The nominee must be a board member and the current owner of the truck.
  • The must be together and able to move on its own power.
  • The truck has to be licensed for street use.
  • If a truck was selected as a 2018 TOTM winner then you are ineligible. If the truck was nominated but not selected as a TOTM winner then it may be nominated and compete in this month's category.
To Nominate:
You or someone else may nominate the vehicle. The nominee must be a board member and the current owner of the truck. Once you decide on who you wish to nominate, just add your nomination to this thread. We will need two pictures minimum (at least one full view of the vehicle) with/for the nomination as well as the owner’s board name, the Make/Model/Year of vehicle.
Nominations will run through January 24. The first 15 nominees that meet the criteria will participate in the contest We will need two pictures minimum (at least one full view of the vehicle) with/for the nomination as well as the owner’s board name, the Make/Model/Year of vehicle. I will PM the nominees to get any additional data or pictures if they have not already been provided. If the owner has a preferred picture they want used in the contest, please let me know in a PM. You can PM me for an e-mail address in case anyone has problems resizing the pictures for the board. A Poll Thread will be set up by January 25 in this board area and an announcement will be posted on the Discussion Boards to notify all that voting has begun. The Poll will run thru the morning of February 1 and the official announcement of the winner will be on the evening of February 1. The announcement of the TOTM winner will be posted through the General Discussion Board area.
Palf70Step is online now
Old 01-16-2019, 11:19 AM   #2
3757chevy
3757chevy's Avatar
Re: February 2019 ToTM
I ' ll throw mine in the fire.( so to speak )....'72 K5 350/TH350/PS/PB/AC/32x11.5-15BFG's on 15x8 Rally Wheels
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline
Old 01-16-2019, 01:05 PM   #3
duke_lbz
duke_lbz's Avatar
I'll throw mine in 72 K5 350/sm465
07 GMC Sierra 2500 compound turbo' duramax
99 GMC Yukon solid axle swapped
67 Chevy c10 small window swb stepside supercharged ls6
70 Chevy c10 suburban
72 K5 Blazer 4wd
duke_lbz is offline
Old 01-16-2019, 01:57 PM   #4
hemi43
hemi43's Avatar
Here's mine !!
hemi43 is offline
Old 01-16-2019, 08:37 PM   #5
YBNORML
YBNORML's Avatar
Might as well throw mine in the mix.
Factory 2wd with a 454/400
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
YBNORML is offline
Old 01-17-2019, 12:44 AM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
Tossing my ride into the ring.
1991 V1500 Blazer, 5.3LS swap/700r4/241/D44 (Tru-trac)/ 14bff 4.10 gears, 1982 Four Wheel Pop-up Camper.
Nearing the summit of Red Cone Pass, CO
At the summit of Mosquito Pass, CO
The LS Swap.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline
Old 01-17-2019, 03:40 AM   #7
Green Monster
Green Monster's Avatar
My 1972 Chevy Blazer CST wearing its original olive green paint. 350 CID and 350 TH transmission. 3" lift with Weld Super Single 15" x 10" wheels and wrapped in 33" x 12.5" BFGoodrich All-Terrain tires.
Green Monster is offline
Old 01-18-2019, 07:35 AM   #8
smbrouss70
smbrouss70's Avatar
I guess I'll give it a shot.
Here is my original paint, factory 2wd 1970 Blazer. It has a 350 with a 700-R4 for now.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline
Old 01-18-2019, 10:55 AM   #9
fun in dirt
fun in dirt's Avatar
Why not, I'll play ... '72 Bucket
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline
Old 01-18-2019, 04:55 PM   #10
HO455
HO455's Avatar
Just to mix it up some. Here's my baby Blazer at work bringing the blaster home.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
HO455 is offline
Old 01-18-2019, 09:45 PM   #11
Ewr101
Ewr101's Avatar
My 72!
72 Chevy 2WD Blazer
Ewr101 is offline
Old 01-19-2019, 02:50 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's mine for consideration. Original 72 St Louis built 4wd Hawaiian blue Highlander. Retains its original drivetrain with CA emissions intact and the protect-o-plate in the glove box. Painstakingly restored with many NOS parts: http://67-72chevytrucks.com/vboard/s...d.php?t=708547
DeadheadNM is offline
Old 01-21-2019, 03:52 PM   #13
cheyguy
cheyguy's Avatar
I always seem to miss the TOTM’s I qualify for so I’m glad to finally get in on one. Here’s my 1975 K5. Thanks for the consideration.
'71 Cheyenne Super
'80 Custom Deluxe
'75 Blazer
cheyguy is offline
Old 01-22-2019, 03:40 PM   #14
knomadd
knomadd's Avatar
I'll nominate Ekliptix and his 1970 Blazer
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline
Old 01-23-2019, 12:51 AM   #15
OldCreek
OldCreek's Avatar
Here's my '71 K/5!
White with Gold Pearlescent paint
6.0 LQ9, 4L60e, NP205
Dana 44 front, H052 posi rear, 4.11's
4" Skyjacker all spring lift, 16.5 Western wheel Turbines, Parnelli Jones 35x12.5r16.5
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline
Old 01-23-2019, 11:58 AM   #16
jaros44sr
jaros44sr's Avatar
Tough choice, you've some of the best on the board!!
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline
Old 01-24-2019, 01:44 PM   #17
enduroride
enduroride's Avatar
Love the background shot in the 3rd picture !
2016 Silverado2005 GMC Sierra
2002 Chevy Slverado Extra Cab (youngest sons)
2009 GMC Denali (oldest sons)
2015 Lexus 250i (wifes)
1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY"
http://www.louisianaclassictruckclub.com
enduroride is offline
Old 01-24-2019, 03:21 PM   #18
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
This one is going to be a tuffy to choose just one of these primo Blazers/Jimmys.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Closed Thread
