12-29-2018, 12:28 PM | #1 |
56 3100 4X4 build
I'm new to this forum and looking for advice on what direction to
build my 56 4X4. Truck has a correct Napco front axle, 23 spicer transfer case and SM465 trans. Plan to do a frame off restoration but want it to have a disc brake front axle, 3 or 4 speed auto, power steering and power brakes. I have read several threads with builds using a later 73-87 frame and a few that have kept the original frame. Power steering location seems to be the biggest problem on the original frame. My truck has a SB with headers and there seems to be plenty of room for a CPP box in the stock location. Drag link would be the problem? My only concern with using a 73-87 frame and the EZ-swap kit would be the height of the truck. As it is now with 33" tires I have just a inch clearance getting into the garage door opening. I plan on running 16" stock steel wheels with skinning tires and about 31" tall. I'm a body-man and fabricator by trade and bought this as my retirement project. Thanks for any advice, Ron Last edited by 1957Napcofan; 12-29-2018 at 01:05 PM. |
12-29-2018, 02:17 PM | #2 |
Re: 56 3100 4X4 build
Welcome...
Looks like a good solid start...swapping a axle won't change your ride height...unless axle diameter is bigger...and that may be your best option....read thru Old57 s build....he did a frame swap..
12-29-2018, 06:32 PM | #3 |
Based on the price of a 73-87 in my area, I would think an EZ chassis swap would be a easier and possibly cheaper way to go but if I had a real Napco, I do t think I would go that route. Old57’s thread is a good read either way.
53’ GMC COE 55.2’ Chevy 3100 short step 67’ Dodge D200 Crew Cab 70’ Chevy C10 LWB |
12-29-2018, 06:33 PM | #4 |
12-29-2018, 08:02 PM | #5 |
That looks like a nice start. If it's a real NAPCO, you could sell the original NAPCO conversion parts. They're worth good money, but it's not practical to keep them for a daily driver, plus the parts are rare and hard to come by if you break anything. If you decide to put it on a 73-87 frame, and don't use lifted springs, it'll sit about like it does now. If you want modern axles with disc brakes and better gearing, you could put the 73-87 axles under it using the frame and springs that you have now. The CPP power steering might work to do that. Also, a Jeep power steering box mounts inside the frame, so you'd have better turning clearance with the stock straight frame rails. I changed mine to the 73 K20 chassis (3/4 ton), with a big block and heavy duty drive train. I wanted the thicker/stronger chassis for what I will be doing with my truck, like pulling trailers, hauling things, a little 4-wheeling, etc. If you have any questions about the 73-87 swap, I can answer those for you. My thread has a lot of pictures too.
My 57 GMC build |
12-29-2018, 08:13 PM | #6 | |
Really super nice truck. |
12-29-2018, 08:23 PM | #7 |
Thanks!
My 57 GMC build |
12-29-2018, 08:30 PM | #8 |
Do you know what the height of your truck is? My 56 as it sits is 79" and my garage opening is 81.5" Not much room to spare. I thought I read somewhere that the ez-swap
kit raises the body about 6 inches, maybe that's compared to a 2 wheel drive. I can get a complete 73 to 87 frame and axles for about $400 to 600 from a local yard here. Last edited by 1957Napcofan; 12-29-2018 at 08:37 PM. |
12-29-2018, 08:55 PM | #9 | |
My 57 GMC build |
12-29-2018, 09:10 PM | #10 |
purcell (joe) did a dodge 4x4 frame swap, seemed to work out well.
http://67-72chevytrucks.com/vboard/s...589917&page=16
12-29-2018, 11:01 PM | #11 |
wont fit in garage?........chop top......just kidding
12-30-2018, 11:59 AM | #12 |
What if you used a '73-'91 suburban frame wouldn't it set lower on that?
63 k20 with cummins 4bt, owned sence 1982 |
12-31-2018, 01:21 AM | #13 |
I did mine with a blazer frame. With 6" lift, it was WAY too tall for the garage.
01-07-2019, 07:55 PM | #14 |
you by chance didnt sell some parts to a guy from alaska?
01-07-2019, 11:22 PM | #15 |
I sure did, and made a new friend.
01-08-2019, 01:35 AM | #16 |
I'm going with EPAS electric power steering. No power steering box, pump, fluids, belts or hoses. Just cut about 9" out of the column and it bolts in. It torques off the outside of the column so no brackets. It is also adjustable gain. The motor is about the size of a beer can and tucks up under the dash. They make a model specific for your truck. Might be worth looking into.
01-08-2019, 08:54 AM | #17 | |
Some interesting reading: https://www.fordmuscleforums.com/all...stem-epas.html Ebay shows some pretty inexpensive Koyo EPAS columns and there's a guy selling a small circuit which appears to allow one to use the Koyo / Saturn Vue steering column without the normally attached Saturn. https://www.ebay.com/itm/Saturn-Vue-...-/123568393044 |
01-08-2019, 09:13 PM | #18 | |
01-10-2019, 01:38 PM | #19 |
10-30-2022, 11:23 AM | #20 |
Frame back from the powder coaters
10-30-2022, 11:27 AM | #21 |
Had to replace all 4 cab corners, inner and outer and the steps
10-30-2022, 11:29 AM | #22 |
Making progress. Bought new bed sides and they fit great.
10-30-2022, 11:32 AM | #23 |
After 4 years of every weekend and vacation.
10-30-2022, 01:01 PM | #24 |
dang, looks great! is that your one wheel wonder burnout?
4 yrs is actually a fast build for this forum, truk was 8 yrs and some of the people are still working on builds that started before i joined
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-30-2022, 01:13 PM | #25 |
That was already there. I installed a limited slip diff during the restoration
