04-14-2017, 01:47 PM | #1 |
need some advise or suggestions on my small block build
so I picked up a low mileage zz3 motor carb to pan, plans are to build this up allittle for my 61 chev longbed, I plan to keep the sm420 4spd trans, rear end is 390 gears, but will be swapped out to a 308 geared 12bolt...
its not a drag truck and not a daily driver,...more of a weekend warrior that occasionally will see some hard pulles from time to time id like to get close to 400 hp if possible with a nice lumpy exhaust sound im ditching the l98 aluminum heads are on it I will be using a set of 64cc pro comp 190cc heads with 202 and 106 valves with a set of .028 head gaskets to keep the cr close to 9.8-1 or so.. I was planning on getting an air gap performer intake already have a holley 670 that I plan to use I was looking at the lt4 hot cams but really not sure if that's what im looking for... so im basically at a stall point because of cam choice,..i need to make a decision on a cam before I send the heads to the machine shop any help is appreciated
1961 c10 longbed - gone 1964 c10 swb |
04-14-2017, 02:23 PM | #2 | ||
"I ain't nobody, dork."
Re: need some advise or suggestions on my small block build
That old 420 with granny low will sap a lot of your power as it won't be up to any kind of speed shifting. It's your basic old school truck transmission.
"Lumpy" sound can mean a loss of power depending on the cam you choose. You can make 350hp with a 350 extremely easy. A true 350hp engine will have a good seat of the pants feel as you accelerate.
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-14-2017, 02:30 PM | #3 |
im not looking for the thumper cam lumpy sound...just something with a healthy sound...as far as the 420...ya it has been a bear as it is now with the 390 gears...i am thinking the 308 gears will help with that...i dont mind the slow shifting...its not a track truck....but who knows...maybe years down the line it will get a better trans...just not now
04-14-2017, 02:31 PM | #4 |
Post Whore
A couple of different ones we ran back in our smallblock days were a .488/.288 and a .500/.300.. we ran these on what we called our junkyard motors..both sound really good..and made good hp gains with headers and intake..if you just want a barely there cam sound you probably don't want one as big as these
04-14-2017, 02:36 PM | #5 |
oh ya the zz3 is a roller so ill be looking for a roller cam
04-14-2017, 11:14 PM | #6 |
60-66 Nut
I would suggest either the GM cam used in the ZZ6 engine or one with similar specs from Comp or Lunati. The ZZ6 is supposed to be a tad over 400 hp.
