07-18-2018, 01:13 PM | #1 |
Trick for removing stuck differential center pin
My 92 k1500 has needed new rear wheel seals for a while now, but when i tried to remove the axles the center pin on the differential would not come out. I removed the small keeper bolt and no matter what i did the pin would not move. I am guessing that with 270k miles it has wore a groove in the pin.
So is there a trick for getting it apart?
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT "Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C. "1968" C10 Shortbed project |
07-18-2018, 04:05 PM | #2 |
Post Whore
Re: Trick for removing stuck differential center pin
have you tried lightly tapping it with a hammer and punch to see if itll move? .....careful not to knock it to far ...
07-18-2018, 04:08 PM | #3 |
I tapped it pretty good with a hammer and it wont budge.
07-18-2018, 04:49 PM | #4 |
Post Whore
part of the cross pin bolt isn't broke off in there is it?...
07-18-2018, 09:49 PM | #5 |
07-19-2018, 06:19 AM | #6 |
I have seen and had a cross pin welded itself to the spider gear . Had to cut it in half to get it out with a side grinder and cut off wheel . Hold the bolt/pin up to the carrier and see if it is long enough to go past the pin . If not the pin is broke off and keeping the pin from coming out . You can try a small magnet to see if it will follow it out . If it is wedged there is a special tool you can use to get it out . May fine some info on YouTube to see how its done .
07-19-2018, 10:27 AM | #7 | |
Never Ending Projects
or did it look like the part on the right, just threads, If so, the long part of the pin is still holding the cross shaft in. In that case you will need a kit like this to work to remove it, https://www.summitracing.com/parts/y...hoC6noQAvD_BwE
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-19-2018, 01:05 PM | #8 |
Wow. Great pictures, chevy_mike. I can see how a break like that would fool any of us. I'll be getting into mine in the next year or two.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
07-19-2018, 09:03 PM | #9 | |
Definately wasnt that long, but had a little bit of the pin still attached to the threads. never would have guessed it was broke.
