Old 08-07-2018, 01:25 PM   #1
NASTY-LSX
73-87 WINDSHEILD SEAL - DELUXE, Cheap or expensive? does it matter
I was on BROTHERS TRUCKS website and called for a order. For front and rear
windsheild with chrome trim was $126 bucks. I told him to hold off and would call back. I called local glass shops and they want $18 bucks a piece.
Do the seals come from one place?? would there be a difference from
cheap and expensive seals?? If I have to pay the $$$$$$ for good seals
I will, But if I dont have to, I wont.
Where do you buy from?? or best place??
NASTY-LSX is offline   Reply With Quote
Old 08-07-2018, 04:35 PM   #2
1957 Chief
Re: 73-87 WINDSHEILD SEAL - DELUXE, Cheap or expensive? does it matter
I just had my front window replaced. The glass guy said he would only install a Precision Brand seal. I paid him for it and it was like 33 bucks.
Bubba
1957 Chief is offline   Reply With Quote
Old 08-07-2018, 06:24 PM   #3
Eman
I use Precision windshield moldings and gaskets every day...they're good quality
Eman is offline   Reply With Quote
Old 08-07-2018, 07:58 PM   #4
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
When the local glass shop put in my windshield replacement, they didnt want to put the chrome strip in but I insisted. After 2 years, it turned all brown. Now its peeling. Not sure what brand they used, but it must have been the cheapest one they could find.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 08-07-2018, 08:02 PM   #5
gmachinz
Weird. I have a couple sets of GM still in the box NOS-they better not turn brown!
Specializing in building electrical harnesses and cooling systems
HARNESSWORX
"An army may march great distances without distress, if it marches through country where the enemy is not."
-Sun Tzu: The Art of War
gmachinz is offline   Reply With Quote
Old 08-09-2018, 02:11 PM   #6
rgunlock
rgunlock's Avatar
I bought a recommended name brand windshield gasket. I laid it out in the driveway in the sun for hours prior to the glass guy showing up, but he still had a heck of a time getting the windshield installed with the locking strip. He claimed that the new rubber was just too stiff. A few weeks later I noticed I had a crack in a lower corner of the glass. Same guy came back out with a new windshield and a couple of OEM gaskets from the salvage yard so I could choose one. Cleaned it up, glass went in with no problem and I've had no problem since. He flat out said that if your original isn't torn up, never get rid of it. Clean it up and re-use it.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Thread
59 Chevy SWB Stepside (next in line)
rgunlock is offline   Reply With Quote
Old 08-09-2018, 05:06 PM   #7
gmachinz
The trick is to use lots of Dawn dishsoap to aid in positioning the seal around the glass, then inserting the assembly into the channel and using liberal amounts of soap to insert the locking bead whether plain black or chrome.
HARNESSWORX
Old 08-10-2018, 09:46 AM   #8
1957 Chief
That's truth right there. My glass guy said the exact same thing.
Bubba
Old 08-12-2018, 02:08 PM   #9
Pontiac1976
Pontiac1976's Avatar
Well I have did both the plain black hold up for longer looking nice, but the chrome will turn when exposed to UV light Heat & dirt after years. The less it see the longer the chrome last.
I do like the chrome look. I was thinking of getting a used black one painting the bubble side chrome seeing how long it last in back yard sitting in sun light rain a few years not moving.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
