Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-04-2018, 09:00 PM   #1
svr
svr's Avatar
Best order to do base coat clear coat on 2 tone
Ok heres where im at, truck is in pieces and i am painting the parts as i go. I am useing urethane 2 part primer and 2 part urethane base and clear. Easy to figure out on the parts that will be only one color, prime, sand then base coat and clear coat within tech sheet requirement of 30 min to 24 hrs. Problem comes with how to get 2 tone lines in proper place with out haveing truck assembled.
Should i paint the complete truck the primary color with clear coat then assemble and do the second color on top of the primary color and clear coat after i mask off the lines? Or should i just do primary base coat then wait until assemled and do the second color and clear the whole thing then, would require scuffing either way it looks like to me. Trying to not pull a giant screw up in this process.
Any thoughts or suggestions would be appreciated.
svr is offline   Reply With Quote
Old 08-09-2018, 07:04 PM   #2
72HuggerK20
Re: Best order to do base coat clear coat on 2 tone
Paint and clear all door jambs, the inside of the cab, the inside of the fenders, etc. with the primary color. Overspray all edges out onto the main body of the truck. Then put the truck together minus the box. Scuff everything outside that'll get the finish paint job with silver scotch brite Mask it all off with foam masking tape in your door gaps and fender gaps. Back mask anywhere you can like under the rocker panels. Then hit it with wax and grease remover, wipe it down, and shoot the secondary color basecoat (or whatever color is lighter, assuming white if it is a 67-72) where it needs to be, overspraying under where the primary color needs to be. Wait the recommended time before taping, then mask it off. Shoot your primary color. Then clear it all when you are done with both colors.
72HuggerK20 is offline   Reply With Quote
Old 08-10-2018, 02:54 PM   #3
MARTINSR
MARTINSR's Avatar
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 08-10-2018, 10:22 PM   #4
68c10airstream
68c10airstream's Avatar
Foam masking tape? Never heard of this. Tell me more!
68c10airstream is offline   Reply With Quote
Old 08-10-2018, 10:29 PM   #5
MARTINSR
MARTINSR's Avatar
It doesn't leave a "hard" edge there are a bunch of Youtube videos on it.
Brian
1948 Chevy pickup
Old 08-10-2018, 11:26 PM   #6
mongocanfly
I used the foam when I painted my red truck.....with great results!!!!
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 08-11-2018, 01:52 AM   #7
MARTINSR
MARTINSR's Avatar
I personally am not a big fan, I just "back tape", but I am old school. LOL
Brian
1948 Chevy pickup
Old 08-11-2018, 07:57 AM   #8
72HuggerK20
Back taping works great too. Sometimes it's hard to get it pressed on for a good seal though in a door jamb. Whenever I use the foam stuff, I tape the back side (the side pointing into the cab) down with regular masking tape to hold it in place better. Another good use for it is when matching the soft edge on replacement rocker panel coating on newer vehicles.
Old 08-11-2018, 11:08 AM   #9
MARTINSR
MARTINSR's Avatar
I see it used very well, and I have seen it used where it turns out like crap with a huge "blended" area without any proper shine or coverage. So it's like anything else, I just have't gotten good with it, I am sure it can work well, I have seen it. I am just an old dude. LOL
Brian
1948 Chevy pickup
Copyright ©2000 - 2018, vBulletin Solutions Inc.
