Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 07-09-2018, 10:03 PM   #1
DD1
Frame Support Rail Questions
I removed the bed from my 71 C10 truck and have some questions about the support rails, and am hoping someone can help. Thanks for taking the time to read and/or respond.
Can I replace this frame rail with a piece of steel bar? I don't see why it would need to be exactly the same size and shape of the original? Is a replacement even available and what would I search for? Do I even need to replace it? It's so thin, it seems almost useless.
Is this frame rail supposed to have those indentations or is this one damaged?
___________________________________________
Darien
1971 C10 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=502964
DD1 is offline   Reply With Quote
Old 07-09-2018, 10:41 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Frame Support Rail Questions
place a want to buy ad the parts section , Depending on which ones you need I have all of them .Drill out the old rivits and install the new ones with grade 8 bolts and your done .
Grumpy old man is offline   Reply With Quote
Old 07-13-2018, 04:34 PM   #3
DD1
Thanks for the advice, I appreciate it.
But I still need to know if the larger rail with the indentation is supposed to be like that?
Also, considering that the smaller rail in the photo is such a thin metal anyway, does it need to be replaced with the exact piece? I don't see why a thick piece of steel bar from Home Depot would not do the same job, but I would like to get a 2nd opinion before I do that.
Is the thin rail even needed? It does not seem to be doing very much.
Darien
1971 C10 LWB
Old 07-14-2018, 09:17 PM   #4
ray_mcavoy
I think the larger crossmember is supposed to be straight, not indented like that.
And I believe the smaller thinner crossmember is only needed if you are using an under-bed spare tire carrier. It just gives the top side of the spare tire something to fit tight up against. So it could be replaced with a piece of angle iron, box steel tubing, etc.
ray_mcavoy is offline   Reply With Quote
Old 07-15-2018, 11:15 AM   #5
DD1
Thank You! I appreciate the help. I had a feeling that the large one might be damaged, especially since it looks like the bed probably bolts into it.
Darien
1971 C10 LWB
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
