Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 08-08-2018, 01:13 AM   #1
HRD
How to approach this?
I'm totally new at body work.
The pictures: #1 is the front of my inner fender panels and #2 is the side of the inner fender panel. These panels are good except for the fronts of them.
There is no patch panels that I'm aware of that could be welded on to get rid of all the pitting that is on front of them.
The bottom third would have to be replaced to get high enough to have good enough metal to even weld a patch on the front of them. That I have already done on one.
But...How do you cover/smooth the rest of the upper 2 thirds of it? Are can it be done?
I'm not building a show winner but would like for it to look decent.
Hollis
HRD is offline   Reply With Quote
Old 08-08-2018, 01:17 AM   #2
mongocanfly
Re: How to approach this?
I would just replace them if possible...if your wanting to just smooth them and there's no other damage then I'd sandblast them...epoxy prime and skim coat body filler over them...
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
mongocanfly is online now   Reply With Quote
Old 08-08-2018, 11:25 AM   #3
MARTINSR
MARTINSR's Avatar
If they are solid, but just severe rust pits as it looks to me, sand blast and then use Polyester primer on them. Polyester primer in four coats can bury a dime taped to the surface, no kidding. Polyester primer is basically "sprayable bondo."
So, it is MUCH easier to finish off than if you were to spread filler on it. Polyester primer is not for everything, but exactly what I would use on something like that.
Feather fill is what I would go with.
http://www.evercoat.com/evercoat-primers/us/
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 08-08-2018, 01:57 PM   #4
mongocanfly
Martin...would you not want epoxy on the bare metal first?....
Mongo...aka Greg
Old 08-08-2018, 02:14 PM   #5
MARTINSR
MARTINSR's Avatar
Yes, that is the "Best" way, but if it's clean metal spraying the polyester primer over it is not a big deal either.
The way I look at it is about 99% of body shops across the country don't use epoxy like that, before bondo that sort of thing. It's never been a "standard" but you are very right, it would be the best way to do it.
Good catch.
Brian
1948 Chevy pickup
Old 08-08-2018, 02:17 PM   #6
mongocanfly
Haha...I don't know about catching....I'm still learning all this stuff myself...
Mongo...aka Greg
Old 08-09-2018, 01:37 PM   #7
Macdaddy1
I use liquid sander as my polyester primer and Marin is correct it will fill all of the pis in flat and make them baby butt smooth.
Macdaddy1 is offline   Reply With Quote
Old 08-09-2018, 05:02 PM   #8
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
Brian
What products and procedures that a "collision" shop use doesn't always translate into the "restoration" shop.
Production body shops don't epoxy because 1. time constraints 2. insurance companies won't pay for it.
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 08-09-2018, 05:24 PM   #9
MARTINSR
MARTINSR's Avatar
I hear you Eric, but that doesn't change the facts.
1. Spraying a quality epoxy primer over your bare metal before filler or paint prep is the best way to treat bare metal.
2. 99% of body repairs across America aren't done that way and survive.
Applying the epoxy steps up the game quite a bit. Plus when doing stuff around the garage that are going to be a multi year project, epoxy over the bare metal allows you to work those years without issues.
Brian
1948 Chevy pickup
Old 08-12-2018, 02:58 AM   #10
HRD
Thanks fellows for the replies.
They are replaceable after markets available.
As stated, I'm new at this and/but I willing to learn. If I screw them up, I'll go that route and replace them. These are hidden somewhat and won't be that noticeable I'm thinking. Going to patch the lower third and smooth out the upper if that's possible. I'll be undercoating the back side so that'll help cover things there.
I'm new at welding too, but I'm gonna try. If I can do a decent job on these before I get to my body panels it'll give me a little more confidence.
Ordered a gallon of the Feather FillŪ G2, Friday. Got a 2.0 sprayer I hope will spray it. Done a little bit of spraying, not much. A few file cabinets and such.
It does say this in the data sheet,
NOTE: All bare metal areas larger than one inch in diameter must be treated with a high quality self-etch or epoxy primer.
I will be putting epoxy on first and planning on just spraying this on the fronts to fill the pitting out smooth.
Practiced blasting today and wore my tip out in about 5 minutes. (New at this also) Now I got to figure that out.
Hollis
Old 08-12-2018, 11:01 AM   #11
MARTINSR
MARTINSR's Avatar
Yeah, I am thinking real sand blast tips are ceramic and don't wear.
I have done that before, then I got one with a ceramic and it's still being used years later. But come to think of it, my big sand blaster, I don't think it has a ceramic tip, but it may be lined inside with ceramic, I will check it out when I go out today.
Brian
1948 Chevy pickup
Old 08-12-2018, 12:03 PM   #12
HRD
Like I said I'm new at all of this.
I've had a setup similar to this https://www.northerntool.com/shop/to...3483_200693483 for years but never used it. I was using very fine sand. -44 grit size. Just trying it on that old trans cover to see what it was going to do. 5 minutes and the tip had wore those cuts on both sides of it.
I really don't know what tips I should be using.
Hollis
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
