Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 01-10-2015, 09:47 PM   #1
VetteVet
Msgt USAF Ret
VetteVet's Avatar
How our starters work
This may help a lot of you understand how the starter works and be able to trouble shoot them.
The starter cycle starts with the key switch turned to the ST position and power is routed via a 12 gauge purple wire to the neutral safety switch on automatics, and to a neutral or safety switch on the transmission, and some times on the later models, to a clutch switch. From there it goes through the firewall block to the S terminal on the starter solenoid.
The solenoid is an electromagnetic device that also acts a relay. The electromagnetic function pulls the starter bendix lever and throws out the starter gear to engage the flywheel.
At the same time the contact washer in the solenoid inside near the rear, moves to the rear and joins the two main terminals on the starter. The battery cable at the top and the starter field terminal at the bottom.
Note the red arrows.
This feeds battery power to the starter windings through the starter brushes and spins the starter armature turning the starter gear and the flywheel.
When the key is released the key switch goes to the ignition position and
releases power to the solenoid and a spring inside the solenoid returns it to the forward position breaking the contact on the two main terminals for the starter and the cycle stops.
shown below.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline
Old 01-10-2015, 10:18 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: How our starters work
VetteVet you are just amazing man! Great write up. This needs to be put in the electrical stickeys!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 01-11-2015, 12:33 AM   #3
franken
Nice but the large + cable doesn't go through the junction block as suggested in pic #1.
franken is offline
Old 01-11-2015, 01:48 AM   #4
70cst
70cst's Avatar
Great info
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline
