Old 02-14-2018, 04:40 PM   #26
testerdahl
Re: No crank, power good throughout
Originally Posted by 61K10 View Post
could have a bad cell in the batt.
That was my first thought. Auto parts store had it over night on their charger and tested it. It was fine.
testerdahl is offline   Reply With Quote
Old 02-14-2018, 05:36 PM   #27
testerdahl
Update: took battery back to store and got a new one. Cold cranking amps were at 8 volts.
Old 02-14-2018, 06:49 PM   #28
testerdahl
Maybe a final resolution. New battery turned truck right over. I did a parasitic loss test and found a draw from the fuel sending unit. Unplugged that and will deal with it later. I put a new fuel gauge on a while ago and looks like something got messed up.
I'm crossing my fingers for tomorrow morning. Going to let the pickup set all night and try in the morning.
Old 02-14-2018, 06:50 PM   #29
testerdahl
Also, we think (FIL and parts people) think the parasitic loss killed the battery and with our cold weather created a bad cell in the battery. Why the battery passed their inspection is anybody's guess.
Old 02-14-2018, 10:35 PM   #30
cwcarpenter98
I think I am having a similar issue on my 63. All the dummy lights will turn on, but when I turn the key, the dummy lights go dim and nothing else happens. Unfortunately I am at college and my truck is over two hours away at home... It started with no issue after sitting for about a week on January 14. Went back home February 2nd and that's when she didn't want to start. Tried jumping it, and it turned over once, but that was it.
Hopefully you get yours figured out. Definitely tuned in to see the fix.
1963 C10 283 3OTT - Frankentruck
"Mack!? I ain't no Mack, I'm a Peterbilt for dang sakes. Turn on your lights, you moron!"
Old 02-15-2018, 11:00 AM   #31
testerdahl
Went out this morning and it cranked right over with plenty of power from the battery. Looks like a dead cell after all caused by the power drain from the fuel gauge and winter temps. Odd still to me the parts store testing didn't reveal the battery issue - twice.
Hoping this is it and the problem is solved. I have a slew of other things I need to do with the pickup and figuring this out too up a lot of my time. I'll be driving it around today and seeing how it does. Baby steps.
Thanks for everyone's help!
Old 02-15-2018, 11:04 AM   #32
testerdahl
Hopefully you can figure out your issue. It can be a maddening ordeal. If I was a betting man, I'd say battery since it sounds like the truck sits from time to time. Best of luck!
Old 02-15-2018, 02:56 PM   #33
cwcarpenter98
Thanks! That will be the first place I check whenever I go back home and get a chance to work on her.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
