12-21-2018, 02:50 AM | #1 |
Suspension kept bouncing.
There are these rail road tracks that I've crossed over going the speed limit (40 mph) and they are angled, but a couple times I've noticed that the driver side will keep bouncing like I'm still going over bumps. It doesn't always do it but the few times it has it doesn't always stop until I've slowed down a little, maybe 100 ft after crossing. Anyone have any ideas what's up?
12-21-2018, 09:12 AM | #2 |
Re: Suspension kept bouncing.
your shocks most likly need replacement the one on the drive side from what you explain might show oil running down on the exterior of the shock tube , there are a few tests to confirm this ,
12-21-2018, 08:08 PM | #3 |
sure sounds like your front shocks are bad
12-21-2018, 09:44 PM | #4 |
Moderator
Also check the upper shock mount stud where it goes thru the chassis rail...they can elongate the mounting hole as the top mount is in single shear.
There are support brackets sold that mount to the chassis (needs some holes drilled) that puts the top mount in double shear.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
12-22-2018, 04:19 PM | #5 |
U nailed it. That's what it is. Now what, do it myself or a local mechanic?
12-22-2018, 04:22 PM | #6 |
I appreciate the quick feedback it turns out that it is the upper mounting is elongated
12-22-2018, 04:27 PM | #7 |
Turns out it was the upper mounting for the shock absorber it was elongated but I appreciate the quick reply that's why I love these forums
12-22-2018, 09:12 PM | #8 |
Moderator
LMC Truck has the reinforcement kits for $20.00
38-1704 FRONT UPPER SHOCK MOUNT KIT $19.95 http://www.lmctruck.com/icatalog/cb/full.aspx?Page=63 You can do the repairs yourself... LMC Also sell shocks etc....check out their online catalog... ClassicParts has the studs and nuts... https://www.classicparts.com/1963-91...SABEgJtffD_BwE $7 a piece including nuts and washers... Other vendors around as well sell similar kits...just google "C-10 Pickup font shock support"...
12-23-2018, 06:40 AM | #9 |
You mentioned the studs and the nuts, do I need to get those too to complete the project
12-23-2018, 06:31 PM | #10 |
Moderator
Depends on what your original ones look like wear wise etc...
I do like to use new fasteners in these situations, as I always add the extra brackets to any build I am doing....
01-15-2019, 05:22 AM | #11 |
I received the new brackets today from LMC they look pretty solid but the weather going to be installed I don't see how it will stop deal on gated hole when it does not attached to the elongated hole. It attaches to the shock absorber itself which still leaves the elongated hole, so where is the support for the elongated hole is this going to be sufficient is is going to solve the problem I just don't see how it's going to work. I am a newbie but I don't want to drill into the frame if it's not going to serve its purpose
01-15-2019, 05:29 PM | #12 |
A few YouTube vids will help you get a good idea of how the brackets go on. Also, if this was covered I missed it, is your truck lowered or stock height? If it is lowered you will need shocks for a lowered truck. I bought mine from CPP a few years back. They were 50 bucks each and made a huge difference in the way my truck road and drove. I would suggest replacing the rear shocks too. Or atleast do them soon after. I hope this helps. Best of luck to you.
Better to remain silent and be thought a fool than to open your mouth and remove all doubt. - Mark Twain |
01-16-2019, 03:59 AM | #13 |
Gotter done tonight. Took about 3 hrs but glad i did it. Thanks for the advice brother.
