06-12-2017, 06:06 PM | #1 |
A daunting task, rear cab support advice please.
After about two years of disassembly, and collecting parts,(due to budget restraints and slothfullness) I am finally working on my truck. Frame has been stripped and POR15ed, and now I am tackling typical repairs on the cab. The rear cab support is giving me fits. I've used the search box but seem to only get 70's models come up. Does anyone have this removal and replacement documented in their build that I could reference? Any & all advice or tips will be greatly appreciated.
06-12-2017, 07:13 PM | #2 |
But Found Her 25yrs Later!
Re: A daunting task, rear cab support advice please.
Rear cab support brackets on the frame, or the patch panel pieces for the cab?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-12-2017, 07:18 PM | #3 |
06-12-2017, 07:34 PM | #4 |
Scrapper 1
If you have that J hook mount that no body uses .They make new mounts that look like the front ones you have to drill out the pot ribbits out and or grind them off an attach the later modal design
06-12-2017, 08:08 PM | #5 | |
06-12-2017, 08:16 PM | #6 |
Thanks stsalvage, I was trying to describe the rear cab floor support brackets not the cab mounts. Just shows what a novice I am. Appreciate the willingness to help
