02-15-2019, 07:48 PM | #1 |
Pm sent
Hatsie, I sent you a PM
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
02-15-2019, 09:35 PM | #2 |
Re: Pm sent
I sent him one the other day and never heard from him either
Posted via Mobile Device |
02-16-2019, 01:08 AM | #3 |
Re: Pm sent
Well if he reads this I do not need him. The electrical problem I had got resolved, not to my liking. What I needed from him is a wire diagram for some seats. But the seats WILL NOT FIT IN MY SITUATION. So I can not use them anyway.
Man was I peed off. John
02-17-2019, 11:26 AM | #4 |
Moderator
Re: Pm sent
I don't have Ford wiring diagrams past the 1980's.
It's fairly easy to determine what wire does what on any power seat with a power supply... benchtop AC to DC power supply or a 12v battery. If the seat joystick is made of unobtainium you can make up a switch panel with DPDT switches wired as polarity reversing switches or just buy polarity reversing switches... 1 per motor. As I said in my slightly private reply... Electric seats are run by fixed magnet DC motors. Direction of a DC motor is controlled by the polarity on the two motor wires. The 8 way seat has four motors and 10 wires to the switch. The 6 way seat has three motors and 8 wires to the switch. Motor Connections; -Track FORWARD/BACK -Front cushion lift/drop -Rear cushion lift/drop -Recline up/down... ** 8 way only ** -Power + - The track motor usually has shafts out both ends to the tracks. The cushion tilt motors have shafts and yokes that drive scissor lift mechanisms. I'm obviously leaving out inflatable lumbar pillows and seat heating elements but usually those are on separate connectors.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
02-18-2019, 03:08 AM | #5 |
Re: Pm sent
Thanks Hatzie for getting back to me. Since my last message I have changed plans on using the buckets. Going back to bench seat. Spent to much money and time trying to put the buckets in. I did not want to use chevy seats because I feel they do not have the support the newer seats offer. So again thanks, John
