Old 07-14-2019, 12:49 AM   #3501
evilokc
Re: What did you do with your truck today, Part 3
today I spent about 3 hours ( probably closer to 4) installing the A/C condenser and dryer. its really not a difficult job but my core support isn't stock. so nothing meant for stock fits. I was able to use the passenger side vintage air bracket. I didn't care about the driver side. I wanted the passenger side because it has a built in bracket for the dryer and all the hard lines are routed assuming the dryer is there. it worked out well. tomorrow i will start hacking away at the renaming items on the list
1)paint compressor mount
2) mount compressor
3) run hoses
4)review and double check evaporator installation
5) 100 other things i cant think of at the moment.
evilokc is offline   Reply With Quote
Old 07-14-2019, 01:27 AM   #3502
idbeast
I now have front lights, and the English Bulldogs approval!
idbeast is offline   Reply With Quote
Old 07-14-2019, 02:57 AM   #3503
MARTINSR
MARTINSR's Avatar
Good to see you guys getting something done, can't wait to get back to that!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 07-14-2019, 10:57 PM   #3504
evilokc
back at the a/c today. a lot of what I got done isn't photo worthy but its important. I got the compressor mocked. I need to make a spacer but other than that the compressor is ready to polish and the bracket ready for paint. I have the evaporator ready to go back in. I got the rest of the hard lines mocked. I had to do a little trimming on the vintage air bracket and I clearanced the core support. started working on the hoses. this is where It gets complicated. i bought the evaporator kit thinking i could use the a/c hoses i had. the two main hoses will work but im going to either have to buy 2 hoses from vintage air or have new ends put on my hoses. will see which is cheaper. i ordered my inner firewall cover. it should be here this week. i need to install that before i mount the evaporator. so this week im going to be sealing up the firewall and trying to source the 2 hoses. fun day.
Old 07-15-2019, 03:32 AM   #3505
DransportGarage
DransportGarage's Avatar
Got the other fender ready for final primer, and started one of the bed sides. It was 91 degrees, I'm sick of sanding, and I quit early. Another hundred hours or so and I'll be completely in paint!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 07-15-2019, 03:58 AM   #3506
MiraclePieCo
MiraclePieCo's Avatar
Still working on adding the back and side skirts to my Chevelle bucket seats. It pretty much entails removing all the upholstery that I paid to have installed. So far I've spent two days on it. I'm learning more about upholstering than I ever wanted to know. I'll won't bore you with pics yet, but I'll post some when I'm done.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 07-16-2019, 09:37 PM   #3507
MiraclePieCo
Got one seat done. My seats are '67 but I used '66 back covers to eliminate the push button back locks. The back cover mounting systems weren't compatible so I substituted upholstered screw caps to hold them on. Definitely not show quality but good enough for the level of build level that I'm going for in this truck.
Next task, door panels.
Old 07-16-2019, 11:14 PM   #3508
evilokc
those are great looking seats man
Old 07-16-2019, 11:39 PM   #3509
nvrdone
so how does it feel to sit in new seats? hows the position relative to the steering wheel, brakes, shifter etc?
nvrdone is offline   Reply With Quote
Old 07-17-2019, 12:12 AM   #3510
evilokc
a/c continued. i got the missing hose made today. took me about 3 hours. i had to go to two different hose makers before to get it made and then realized i was missing a piece of information that might cause issue. had to drive 20 miles home look at truck drive 20 miles back. got it home and it was a tiny bit long but works. once i had that i mocked the entire system. its gonna work well. took the interior parts and hoses back out and started working on the giant hole in my firewall. to review. my firewall isn't stock it was hacked up and "smoothed" by a professional shop. so the vintage air system didn't fit. i had to hack the firewall up to get it in. the hole was large and im making the patch in two pieces. the main piece is done. i will tac it in tomorrow and then make the second smaller patch. i also have 10 other small holes to fill. i only have a tig set up which isn't optimal for body work but its what i have so i will make it work.
Old 07-17-2019, 02:22 AM   #3511
MiraclePieCo
Thanks. Chevelle bucket seats command ridiculous prices on Ebay. I saw a recovered set last week that got bid up to $2500 and still didn't make reserve.
I set the position specifically for myself, so it's great for me but I can't speak for anyone else. I prefer these old-style seats with no headrests, no bolsters, nothing fancy, just good old black tuck-and-roll.
Old 07-17-2019, 05:15 AM   #3512
DransportGarage
Nice choice on the seats, especially in the sedan delivery. They look great!
Bob
Old 07-17-2019, 10:09 PM   #3513
evilokc
well today was welding day. it didn't go well. I was using a practice piece and I kept burning through. I just couldn't get the tig dialed into it. I was laying decent tacs but as far as welds it wasn't good. I spoke to a buddy and hes going to loan me his mig. that will be a lot easier.
Old 07-17-2019, 11:28 PM   #3514
MiraclePieCo
Thanks, that's a real compliment coming from a guy with a truck as nice as yours.
Today I got the passenger seat installed. Although it's really hard to photograph black interior in a dark garage, I am blown away with how nice these turned out.
Now I turn my attention to making matching door cards.
Old Yesterday, 10:22 AM   #3515
MARTINSR
MARTINSR's Avatar
I had the same seats in my truck back in the seventies! One was white, bought them both out of cars at the wrecking yard. I couldn't find two black ones in good shape. Painted the white one black with SEM rattle can and forgot I ever did it! No kidding, ran them for a few years and not a speck of that SEM came off!
Brian
1948 Chevy pickup
Old Yesterday, 01:24 PM   #3516
Livemeyer
Livemeyer's Avatar
Interesting, I'm looking at your pictures and I see a detail that relates to what I'm doing. I see the driver's door relay in your last picture is mounted 'up' so the triangle shaped mount lines up with all three mount holes. When I take my panels off and look at my door release relays they are mounted upside down to yours and the long bar is flat. My wife had complained the other day that she couldn't get the passenger door open (nevermind that the door alignment is completely fubar) so I ordered a new door relay. I put it in only to realize half (more than half?) the problem is that the interior door handles are completely stripped of gearing. So, now I have ordered new handles too.
Kinda goes along with the other thing I was working on, replacement wipers. Since new wipers won't mount on the original arms, I bought new wiper arms as well. This old truck is keeping me busy for sure! (And, in debt.)
Livemeyer is offline   Reply With Quote
Old Yesterday, 05:19 PM   #3517
MiraclePieCo
Brian
I can't count the number of interiors in the 1970s that I dyed black using Mar-Hyde, but it would always wear off in about a year. Wish I'd known about your SEM technique back then.
Old Yesterday, 09:30 PM   #3518
Black_Sheep
Black_Sheep's Avatar
MPC the seats look great and I bet they are pretty comfortable too.
I had to fix the power cord on my garage fan before I could even start working on the truck. Cleaned up, fluids checked and full of fuel. Headed to the Summer Nationals tomorrow morning...
Black_Sheep is offline   Reply With Quote
Old Yesterday, 09:38 PM   #3519
evilokc
got another small patch done. they are tacked in but that's as far as I got. I need to make one more patch to close off the 4 holes above it and then I can finish weld and clean up the patches. I also have several small bolt holes to fill. I know its ugly now but I will get it smooth as a gorillas butt
Old Yesterday, 09:40 PM   #3520
Black_Sheep
Old Today, 12:36 AM   #3521
Livemeyer
Livemeyer's Avatar
That's a gorgeous truck, inside and out. And I want your super clean garage too.
Old Today, 12:41 AM   #3522
Livemeyer
Livemeyer's Avatar
I was able to remount my heater core after having had removed it, sanded all the rust and spray painted it. Not planning to hook it up to the radiator at this time; was more to block the heat coming through the firewall rather than provide heat.
Got started on installing new windlace on passenger side. This is unbearably difficult. I started at the rear of the door at the bottom and made it up to the top corner, but the corner and the top have proven to be a greater challenge, especially since I'm trying to not mess up the new cardboard headliner I just installed.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
