09-18-2011, 04:29 PM | #1 |
Is there a cab corner that fits
I,m tring to replace my cab corners I bought a pair of Counterpart corners and as you can see from the pictures there not a quality part. First they don,t have the same body line on the bottom, the corner radius is different, there is not a lip below the lower spot weld flange, the door spot weld flange tapers.
Over all it,s a piece of S--- NEED HELP Does someone know of a cab corner that is better Thanks for the help |
09-18-2011, 05:35 PM | #2 | |
But Found Her 25yrs Later!
Re: Is there a cab corner that fits
That Counterpart corner is crap!
Take it back and get Keyparts (TriPlus). Quote:
09-18-2011, 05:42 PM | #3 |
Also,
You may already know this, but... A tip mentioned in these forums is to only cut out what you need to replace. In other words; don't cut your truck to fit the patch panel, but cut the patch panel to fit the bad portion that needs replacing on your truck.
09-18-2011, 06:01 PM | #4 |
60-66 Nut
Where did you purchase those cab corners LostMy65?
I believe MBGMike was selling USA made cab corners not long ago. I don't know if he still has any though. http://www.bumpandgrindgarage.com/ http://67-72chevytrucks.com/vboard/s...d.php?t=474845
09-18-2011, 08:39 PM | #5 |
Classic parts is only selling the new ones that fit perfect . I had got a left side first but had not installed it and it did not fit very good at all. Then i got the right side and it was if it was an OEM one (Perfect in every detail) but repop. They said send the left side back and they would send me the new type left side one. I got it and it also fit perfect and had all the factory lips and bends.
09-18-2011, 09:02 PM | #6 |
Thanks for the info I will call classic tomorrow
09-19-2011, 12:31 AM | #7 | |
09-28-2017, 12:05 PM | #8 |
Too bad photo bucket is dumping our pics. The photos I posted above really emphasized the difference in quality.
09-30-2017, 06:02 PM | #9 |
Almost all repos parts needs a little tweaking.
10-01-2017, 03:50 PM | #10 |
ALL reproduction sheet metal requires some fabrication. Blame the Chinese, their quality control sucks. 99% of all reproduction parts for trucks and cars is imported. An American made cab corner, if there were such a thing, would probably cost $500.00 a piece, not 20 bucks. As a former employee of the largest classic car/truck parts supplier, I've been to the factories on multiple occasions in China, there is only two of them. They tend to use stamping dies past their prime, after they should have been replaced. Which causes some of the fluctuations in quality. Some parts suppliers are better at culling out inferior parts, some aren't. It's a crap shoot.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside Last edited by oldusafmsgt; 10-02-2017 at 10:50 AM. |
10-01-2017, 08:26 PM | #11 |
There was a definite difference in shape of the contours between the triplus and counterpart brand. The gauge of steel was also easily evident. I'll see if I can find those pics again and repost them.
All reproduction body pieces or patch panels won't fit as well as original pieces, but there is inferior brands of patch panels.
10-02-2017, 10:52 AM | #12 |
There isn't any different "brands" , only different importers. If you read the UPC code, you'll see they all come from the same place, same country.
1960 Chevy Apache10 Short Fleetside 1961 Chevy Apache10 Short Fleetside 1961 Chevy Apache20 Fleetside 1963 Chevy C10 Short Fleetside 1965 Chevy C10 Short Stepside 1965 Chevy C10 Long Fleetside 1966 GMC 1000 Long Fleetside 1966 Chevy C10 Short Fleetside |
10-02-2017, 11:02 AM | #13 |
China chit.
10-02-2017, 12:01 PM | #14 | ||
See this link: http://67-72chevytrucks.com/vboard/s...d.php?t=535140\ . Also: Quote:
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 10-02-2017 at 06:08 PM. |
