Old 12-18-2007, 08:55 AM   #1
Albertan
Albertan's Avatar
Unhappy Radio bulbs burnt out
I have a 2000 chev 1500 . everything works , but some of the lights in the radio /cd player do not work. I thought it was just a couple of bulbs burnt out, but after taking the front panel off, I found they were L.E.D.'s (?) soldered in. I could not tell if they were burnt out, and I new I could not just change the bulbs out, so I put the panel back together, and now more are not working!!!
Does anyone repair these? Or, has anyone repaired these?
Albertan
My toy's
1972 Cheyenne C10
1926 Model T Depot Hack
1926 Model T Roadster
Albertan is offline   Reply With Quote
Old 12-19-2007, 08:11 AM   #2
BP68
BP68's Avatar
Re: Radio bulbs burnt out
I work at a Dealership and see this often. We have to send them out for exchange. I have taken them apart before, and if you are carful and can find a close enough bulb, you should be able to solder in new ones.
I have one out on my radio right now. I banged just above it on the dash a couple times one night, and now it is staying lit.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-19-2007, 11:13 AM   #3
Albertan
Albertan's Avatar
So they are bulbs and not LED's. What a stupid way to light the radio. What ever happened to the good old push in bulbs??
Were do you get your bulbs? Thanks for your reply BP68
Albertan
My toy's
1972 Cheyenne C10
Old 12-20-2007, 06:09 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
The bulb on my recirculate button burnt out last year. Sounds like I'll just leave it alone
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-20-2007, 05:46 PM   #5
Albertan
Albertan's Avatar
Re:Safety issue? Radio bulbs burnt out
now that you mention it I think my recic. button is not lit also. Why do they have to make it so hard to change out the bulbs??? Is it not a saftey concern...trying to fumble with bottons you can not see?!
Another job well done Mr. Young-Engineer!
Albertan
My toy's
1972 Cheyenne C10
Old 12-21-2007, 12:12 PM   #6
michael bustamante
michael bustamante's Avatar
I work for a extended warranty company ad this is a VERY common problem, most of my lights in my heater control in my Impala are burnt out as well. pretty much our only fix is to replace the control face itself.
1967custom
michael bustamante is offline   Reply With Quote
Old 01-02-2008, 02:34 AM   #7
Nickpisp
Those aren't hard to fix, just solder in a new LED from Radio Shack.
Nickpisp is offline   Reply With Quote
Old 01-02-2008, 04:15 PM   #8
Albertan
Albertan's Avatar
I take it they are 12 volt LEDS. I think I'll try that...I don't have anything to lose.
Albertan
My toy's
1972 Cheyenne C10
Old 01-05-2008, 12:06 PM   #9
Nickpisp
Correct, I just unsoldered the old ones and took them to radio shack to find the ones that matched.
Old 01-05-2008, 12:54 PM   #10
edman87
junk collector
I reparied a pioneer face, just soldered in 8 or 9 new leds. It is not hard and I am not that good with a soldering iron, in fact it was a cheapo 99 cent iron at that.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 01-05-2008, 07:10 PM   #11
Albertan
Albertan's Avatar
Re:more problems besides burnt out bulbs on other truck
thanks guy's .....Now can you help me with my 1994 GMC. The other day I shut the truck off and the radio stayed on for a quite awhile before shutting off! The 2000 has a feature that the radio stays on untill you open the door, But the 1994 does not have this feature, it just started to do it it's self! I would think it is a sticky relay, but where would I find it?
Peter.
Albertan
My toy's
1972 Cheyenne C10
Old 01-28-2008, 03:56 AM   #12
STAS 19
Back to the radio lights being out, if it's the stock radio/cd player then most of the lights are little bulbs not leds. They look almost the same but these bulbs are closer looking to mini mag light bulbs. Get em at radio shack for $1 each (12volt). The only LED I remember in my radio was for the power indicating light next to the on/off, vol control. Easy fix with solder iron if you DIY.
STAS 19 is offline   Reply With Quote
Old 01-28-2008, 11:55 AM   #13
Albertan
Albertan's Avatar
Thanks so Much STAS 19!!! I did not look real colse to see if they were bulbs , or LEDs. I have been putting the repair off , but I'll want to get them replaced. Next time I'm in the big city , I will stop and pick up a hand full!
Thanks Again, Peter.
Albertan
My toy's
1972 Cheyenne C10
Old 01-31-2008, 12:37 PM   #14
BP68
BP68's Avatar
I was going to rob some bulbs out of a old radio we had at the dealer, but haven't had to so far. If any bulbs go out after my warranty is up, I will be doing the DIY repair. BTW my dad has a 01 F150 and the LCD odometer kept going on and off. A quick search on a F150 forum showed me where to find the broken solder on one of the pins and we fixed it right up.
03 Grand Prix GTP
Old 01-31-2008, 02:30 PM   #15
Albertan
Albertan's Avatar
Yes, using Forums like this sure helps fix a lot of stuff! Even just following the threads, you learn a lot. I use this one and a model t forum all the time.
Peter.
Albertan
My toy's
1972 Cheyenne C10
