04-01-2013, 02:52 PM | #1 |
Cranking signal wire in 4.8 1967 C10 conversion
I'm putting a 2003 4.8 into my 1967 C10. Motor is installed in the truck. I have a current performance wiring harness. It has a cranking signal wiring in the new harness. My question is where would I hook it up to in the original C10 harness (what color wire please). Thanks for any help in advance
04-02-2013, 12:39 AM | #2 |
Re: Cranking signal wire in 4.8 1967 C10 conversion
I also used current performance also. My truck is 69 c/10 I used the wire that fed the coil on the positive side. I also traced this wire back to the bulkHead and removed it out of the bulkhead and replaced the wire with a new one since the old was one of those that was designed to drop voltage for points system. It had a cloth type sheathing. My wire color was yellow. I'll bet yours is the same. Hope you understood this.
Posted via Mobile Device |
04-02-2013, 12:57 AM | #3 |
Oh yeah how about some photos. I also run a 4.8 that motor rocks people just don't give it enough credit I'm speaking from experience.
04-02-2013, 08:22 AM | #4 |
If your asking about the ignition hot all through the cranking, I used an accessory connection off the fuse block (EZ Wiring harnes block)
I too have the 4.8 and think it doesnt get the credit it deserves.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-02-2013, 11:52 AM | #5 |
I think I follow what you're saying. I will try that this afternoon. Thanks for the help. The 4.8 was extremely cheap
