Old 02-25-2019, 10:21 PM   #1
shultzee13
5.7L Vortec Intake Breather assembly Gasket
Underneath the breather assembly hose where it connects to the throttle body there is a round orange gasket. Mine is gone.
Does anybody have a party number or where to buy?
Mine is gone.
1999 suburban OBS 5.7L RWD.
I am getting codes PO171/174 and I am thinking there is where it is sucking air.
shultzee13 is offline   Reply With Quote
Old 02-26-2019, 07:55 AM   #2
Re: 5.7L Vortec Intake Breather assembly Gasket
I normall use spray carb cleaner and spray the areas where I think it is leaking to see if how it run changes. If it does that is where the leak is.
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 03-06-2019, 06:57 PM   #3
speedygonzales
speedygonzales's Avatar
Not gonna find it
Not only is that O ring not available. Neither is the original elbow the oring was in.
Why not just put a bead of RTV around the inner area where the o ring would be and seat it and leave it. When it dries, if you need to remove it, it will peel off and you can always replace it.
I noticed the K&N filter assembly has an elbow that attaches to the throttle body. Perhaps they have replacement parts for their assemblies.
Part number 57-3013-2
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 03-22-2019, 05:22 PM   #4
AussieinNC
AussieinNC's Avatar
Take the elbow where the O ring seats to local parts store...they usually have a selection of O rings...try and find a Viton one...usually Orange or Blue,,,rather than a cheap black one....
Just make sure the section thickness is correct....too thin and it wont seal, too thick and it wont fit into the port....
The original O rings haven't been available for a while now...
Family and country before all others...
1967 C-10 LWB (Project)
2001 GMC Sierra
2006 Chevy Silverado (Daily Driver)
AussieinNC is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
