08-15-2015, 07:40 PM | #1 |
Door weatherstrip questions
Is there supposed to be a channel, that holds the rubber weatherstrip over the door, on the fiberglass top of a blazer? If so where can I find some?
08-15-2015, 08:23 PM | #2 |
Re: Door weatherstrip questions
This is a picture of the area in question.
08-15-2015, 08:25 PM | #3 |
It is a double wall top if it matters
08-16-2015, 10:00 PM | #4 |
I am unsure on the double wall by there is a channel on my single wall. I used to have a double wall top blazer about 8 years ago and I don't think it had the channel. I believe it just glued to the top.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
08-16-2015, 11:32 PM | #5 |
Double wall tops use retainer clips. LMC p/n 30-1601.
I believe it's advisable to use weather strip adhesive also.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
08-17-2015, 09:13 AM | #6 |
if you clean that area up, you will see 3-5 holes that the retainer 'T' clips sit in
08-17-2015, 06:50 PM | #7 |
Thanks for the advise, as I saw the holes, and saw a metal channel in a picture of another blazer.
