Old 03-17-2014, 09:27 PM   #1
69Rumbler
69Rumbler's Avatar
3/4 Ton .. Rear End Swap
im thinking about changing my rear end on my truck , so i can run back disc brakes and well get rid of the leaf and get a coli set up . Wondering what you guys used , what years and make will be an bolt up .
1969 C20 CUSTOM "RUMBLEr"
69Rumbler is offline   Reply With Quote
Old 03-18-2014, 10:32 PM   #2
viking427
Re: 3/4 Ton .. Rear End Swap
Dana 60 coil spring rear is what you want. A bit difficult of a rear to find but there are disc brake kits for them. You probably already have a leaf spring HO52 or dana 60 rear- I'd stick with that and just get a disc kit for it.
viking427 is offline   Reply With Quote
Old 03-18-2014, 10:39 PM   #3
mrolds88
Personally I like the leaves over the coils. Why are you wanting to swap rears? Is it difficult for you to locate brake parts for the H052 where you are at? s far as disc stuff goes, there are a number of kits out there for the H052. Off the top of my head tsmmfg.com has a nice setup. Also check with the vendors on here. Tere is at least one that does at least the brackets for several applications. It would use the same brackets as a FF14 bolt.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-18-2014, 11:29 PM   #4
69Rumbler
69Rumbler's Avatar
Yea I thought it over and I'm sticking with leaf and I'm going to see what kind of rear end I got tomorrow
Old 03-19-2014, 04:15 PM   #5
69Rumbler
69Rumbler's Avatar
Re: 3/4 Ton .. Rear End Swap , Dana 60 ??
this my rear end its a Dana 60 Right ?
Old 03-19-2014, 04:21 PM   #6
69GMCLonghorn
69GMCLonghorn's Avatar
Don't swap the rear end just for the sole purpose of going to disc brakes. I've had a 3/4 ton and a 1 ton and let me tell you, those rear drums will stop a freight train and not break a sweat! The fronts are what should be converted to disc.
69GMCLonghorn is offline   Reply With Quote
Old 03-19-2014, 04:39 PM   #7
Cali72K20
Cali72K20's Avatar
That is a DANA 60, you can see the 60 to right of the filler hole right below the plug weld hole
Cali72K20 is offline   Reply With Quote
Old 03-19-2014, 04:48 PM   #8
69Rumbler
69Rumbler's Avatar
Awesome thanks !
Old 03-19-2014, 05:11 PM   #9
Cali72K20
Cali72K20's Avatar
Here it is
Old 03-19-2014, 06:20 PM   #10
69Rumbler
69Rumbler's Avatar
LMC is good for something hha
Old 03-19-2014, 09:13 PM   #11
viking427
...and a factory rear swaybar too , nice score.
Old 03-19-2014, 09:19 PM   #12
ole dollor
ole dollor's Avatar
I like the leaf springs better, mine has coils so that what I live with..
ole dollor is offline   Reply With Quote
Old 03-19-2014, 09:29 PM   #13
69Rumbler
69Rumbler's Avatar
Yea I just need to find a good deal on a set of springs .. They arnt to expensive but shipping it's killer .
Old 03-19-2014, 11:34 PM   #14
airdale94
airdale94's Avatar
Being in LA you should be able to find a shop that "makes" leaf stacks. I had some made for a 94 I had. I just had to measure the width. What they do is build a stack out of leaf stock they have on hand. They will make you a new set of u-bolts also.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 03-19-2014, 11:45 PM   #15
69Rumbler
69Rumbler's Avatar
In going to call around tomorrow most places I called were out of business ..
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
