Closed Thread
Old 01-26-2014, 01:51 PM   #101
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today? Chapter II
Yesterday I drove the truck to our local chapter of chevy trucks meet in Greenville SC along with some others! First drive since the 6.0 LSx motor install!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 01-26-2014, 02:07 PM   #102
Elliot949
Dan Johnston
Elliot949's Avatar
Originally Posted by Mike_The_Grad View Post
Thanx @ elliot949 &@TeX Jake. Anytime I get two of the same opinions its good enough for me.pictures soon to follow. Any idea on how many cans? I'm gonna paint engine and trans.
Probably no more than 3... the key to this product is to apply it EXACTLY per label... If you do Everything right there will never be a time that you would need a "professional" repaint it...
This product actually is what most Restoration companies use to paint OEM style restoration projects...
Elliot949 is offline
Old 01-26-2014, 02:19 PM   #103
Ridgeclimber
I spent my weekend stripping the paint off of my hood and the front fenders. I used aircraft paint stripper then sanded it down. Very time consuming.
Ridgeclimber is offline
Old 01-26-2014, 02:39 PM   #104
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Oh...My neck!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 01-26-2014, 03:42 PM   #105
texjake
texjake's Avatar
Originally Posted by Originally Posted by Mike_The_Grad View Post
Thanx @ elliot949 &@TeX Jake. Anytime I get two of the same opinions its good enough for me.pictures soon to follow. Any idea on how many cans? I'm gonna paint engine and trans....
Agreed. Apply as per label. I painted a set of headers on my 38' Plymouth ratrod truck last year and once they were installed & I ran the truck they never blistered or discolored. And since I didn't have a oven to cure them in, I painted them in the summer sun when it was 103 degrees outside. And I also did the run cycle as directed just to help cure them from the inside out. Also a great prep surface is the key to getting paint to bond forever.
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 01-26-2014, 11:35 PM   #106
Saclandman
Saclandman's Avatar
Installed my new engine harness, and got the old boy fired up..kinda. Took a lot of fiddling with the timing, but finally got it sputtering with the accelator smashed to the floor. Looked down the carb, pumped the throttle, and just a little bit of gas is dribbling out. I just rebuilt the carb too. It was shooting a nice jet out right after I got it back on the engine. Now, just dribbling. Guess I have to pull the carb apart again.
But it ran, yippee!!!
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 01-27-2014, 02:12 AM   #107
Mike_The_Grad
Mike_The_Grad's Avatar
Awesome thanx again @elliot949 @TeX Jake much appreciated. I'm in so. Cal. And its been really nice weather lately. i.e. 70°-80°. I even have a space heather that can supply the heat over night.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline
Old 01-27-2014, 02:31 AM   #108
First c10
First c10's Avatar
Puts some paint down before we install the new motor!!!!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline
Old 01-27-2014, 07:06 PM   #109
jmorri34
jmorri34's Avatar
Took her on a ride around town, went to the folks house and to get pizzas for dinner before the icepocalyps hits here in houston and the city falls apart!!!
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline
Old 01-27-2014, 07:25 PM   #110
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Hooked up the trailer and drove out to Adam's and bought my new cab ! .
Now I have to wait until Thursday or Friday to take it to the body shop and see what he wants to replace it .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 01-27-2014, 08:07 PM   #111
jmorri34
jmorri34's Avatar
That looks really good, I have been struggling on how to strip all the old paint off my truck it needs to go to metal. All in all did the stripper work well for you and what did you use in the sanding process thanks Jerry
1969 cst prostreet
jmorri34 is offline
Old 01-27-2014, 09:57 PM   #112
VWNate1
VWNate1's Avatar
Exclamation Re : Chemical Stripping
Just be EXTREMELY CAREFUL of chemical burns ! I first used " Aircraft Remover " in the 1960's and got some on my hands and arms , boy howdy was that a bad burn and hurt like the dickens because no water or anything else to remove it from my skin .
-Nate
Geezer
VWNate1 is offline
Old 01-28-2014, 12:49 AM   #113
Ridgeclimber
The aircraft stripper I used worked pretty good. I roughed up the paint with 40 grit just to open up the paint to let the stripper soak in. I had about three coats of old paint on. So it took a coat of stripper for each coat of old paint. Once I scrapped off as much as I could I used 80 grit to remove the rest. Like the previous post said, be careful with it. It will eat through light latex gloves, your clothes et,. were goggles, use in well ventilated area and/or use a respirator.
Old 01-28-2014, 08:54 AM   #114
Elliot949
Dan Johnston
Elliot949's Avatar
Or do like I do and take it to a media blaster and spend the 300.00 and get nice clean parts back... LOL
Old 01-28-2014, 09:33 AM   #115
Ridgeclimber
I looked into getting it blasted. There's a company not too faraway that does it. I was quotes about $125 to $150 a panel. So it would add up pretty quick.
Old 01-28-2014, 09:36 AM   #116
Elliot949
Dan Johnston
Elliot949's Avatar
Typically if you do it all at one time they will cut the deal... I was quoted 125 for fenders and grill and 150 for the hood but they did all 4 pieces for 300...
Old 01-28-2014, 10:04 AM   #117
bigguy69
dazed and confused
bigguy69's Avatar
Originally Posted by andy4639 View Post
yesterday i drove the truck to our local chapter of chevy trucks meet in greenville sc along with some others! First drive since the 6.0 lsx motor install!
you are going to have to change your fender emblems now. Looks good
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline
Old 01-28-2014, 10:24 AM   #118
Ridgeclimber
Does anybody know of a LSX 6 litre emblem that we could use?
Old 01-28-2014, 11:18 AM   #119
texjake
texjake's Avatar
I don't think they make a LSX 6.0 liter fender badge. There are LSX badges out there but not coupled with the 6.0 liter.
texjake is offline
Old 01-28-2014, 12:43 PM   #120
jmorri34
jmorri34's Avatar
I dont think there is a media blaster around the spring tx area where I live or I would, plus the whole truck has to be strippd and I think by using a little elbow grease I should be able to do it myself. Although sure would be easier to have it blasted, as well as cleaner!
1969 cst prostreet
jmorri34 is offline
Old 01-28-2014, 12:43 PM   #121
jmorri34
jmorri34's Avatar
Awesome thanks for the information, I have a bit till I have to get to it but this will help
1969 cst prostreet
jmorri34 is offline
Old 01-28-2014, 01:53 PM   #122
9teen69
9teen69's Avatar
New u-joints and carrier bearing. Should have bought a puller($30)...local brake shop pulled it off and stripped out my threads...now I know why they didn't charge me. $65 later at Scottys Driveshaft fixed the problem...they are the best.
Whooped my butt for awhile...as always the search button was most helpful.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 01-28-2014, 02:43 PM   #123
54blackhornet
54blackhornet's Avatar
Got my wheels back from powder-coating, they look a lot cleaner now !
71 C-20
07 Magnum RT AWD
54blackhornet is offline
Old 01-28-2014, 04:37 PM   #124
OregonNed
OregonNed's Avatar
I test fitted my new seat and figured our how far up I needed to mount my floor shift:
Then removed it and began the fat mat installation:
Then laid the new carpet in to test fit:
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 01-28-2014, 10:49 PM   #125
VWNate1
VWNate1's Avatar
Exclamation Re: What did you do to your truck today? Chapter II
Be aware that media blasting creates heat and can warp panels WAY beyond salvage ~ I've seen this happen many times , even though the company said " yeah , yeah ~ we've been doing this for 20 years and never ruined a panel yet " .
Once your original panels are ruined , you're going to wish you'd chem stripped instead .
-Nate
Geezer
VWNate1 is offline
Closed Thread
