Old 07-01-2022, 03:42 PM   #1
kcstreetracer
Aftermarket steering column
I have a cheap aftermarket chrome column I am installing. I have all the factory hardware from the old column, but I don't see how this will work. The column is not secure and spins while turning the steering wheel and shifting in and out of gears. Can someone who has installed one possibly shed some light on this please. Maybe there is a specific mount I need?
1968 C10 SWB, mild 355,5/7 drop, budget frame off, piecing it back together!
kcstreetracer is offline   Reply With Quote
Old 07-01-2022, 08:11 PM   #2
RustyPile
RustyPile's Avatar
Re: Aftermarket steering column
I have an aftermarket tilt column in my truck, brand unknown.. The bolts and saddle clamp under dash should hold the column in place. Make sure these bolts are tight. The bracket at the firewall is formed into a clamp. This clamp also holds the column.
RustyPile is online now   Reply With Quote
Old 07-01-2022, 08:38 PM   #3
LS short box
As I recall on my stock 68 column there was a small hole in the column that engaged a small "nub" on the column mount bracket. I used a Ididit column and had to drill a small hole in the column to engage the the nub on the column mount bracket.
